KNoCks, CluNkS, and BumpS!?!?
Old Oct 20, 2005 | 05:28 AM
AP Kreuzer's Avatar
Default KNoCks, CluNkS, and BumpS!?!?
Well it has been a couple months since I installed my H&R springs, Tokico Shocks, and Progress rear sway/tie bar. I can't complain about how it performs because its way way better than stock. The thing is that my Progress sway bar is makin awfully alot of noise its getting to the point where I cant even stand it anymore. I know its not my exhaust hitting the bar because I had driven my car with no muffler but the sounds are still there. I can hear it coming from both sides of the rear. I also let my bro rocked it back and forth while i was under the car and I dont see anything out of place?? Any ideas?
Old Oct 20, 2005 | 08:16 AM
AP Kreuzer's Avatar
Default Re: KNoCks, CluNkS, and BumpS!?!? (KnightHawkEP)
anyone?
Old Oct 20, 2005 | 10:40 AM
...me0w's Avatar
might be dumb question but is everything tight as far as nuts and bolts another thing you might try doing is pulling it off and then put it back on something might be in a bind. just my worthless 2 cents
Old Oct 20, 2005 | 11:20 AM
J_Bones's Avatar
hey mak...what kind of endlinks are you using? greys? hotc.?
Old Oct 20, 2005 | 11:39 AM
AP Kreuzer's Avatar
Default Re: KNoCks, CluNkS, and BumpS!?!? (02SHRTBUS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02SHRTBUS &raquo;</TD></TR><TR><TD CLASS="quote">might be dumb question but is everything tight as far as nuts and bolts another thing you might try doing is pulling it off and then put it back on something might be in a bind. just my worthless 2 cents</TD></TR></TABLE>
yeah. I just might have to do that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Junkies &raquo;</TD></TR><TR><TD CLASS="quote">hey mak...what kind of endlinks are you using? greys? hotc.?</TD></TR></TABLE>
I'm on stocks
Old Oct 20, 2005 | 11:51 AM
phthalo's Avatar
GDD4LIFE
when do you hear the noise? what does it sound like?
Old Oct 20, 2005 | 12:40 PM
AP Kreuzer's Avatar
Default Re: KNoCks, CluNkS, and BumpS!?!? (phthalo)
i hear it everytime i go over railroad tracks road humps...sound bad...
Old Oct 20, 2005 | 02:20 PM
DC5ITR329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KnightHawkEP &raquo;</TD></TR><TR><TD CLASS="quote">Well it has been a couple months since I installed my H&R springs, Tokico Shocks, and Progress rear sway/tie bar. I can't complain about how it performs because its way way better than stock. The thing is that my Progress sway bar is makin awfully alot of noise its getting to the point where I cant even stand it anymore. I know its not my exhaust hitting the bar because I had driven my car with no muffler but the sounds are still there. I can hear it coming from both sides of the rear. I also let my bro rocked it back and forth while i was under the car and I dont see anything out of place?? Any ideas? </TD></TR></TABLE>
I had this problem before check all the bolts that hold down the sway. plus check the endlinks. just make sure you tighten everything down to specs.
Old Oct 20, 2005 | 03:06 PM
AP Kreuzer's Avatar
Default Re: KNoCks, CluNkS, and BumpS!?!? (aznbo1626)
well i just got home from honda and it still makin tha popping noise should i get some aftermarket endlinks??
Old Oct 20, 2005 | 03:17 PM
phthalo's Avatar
GDD4LIFE
i think you are just bottoming out on your springs...how much did you lower your car?
Old Oct 20, 2005 | 03:37 PM
AP Kreuzer's Avatar
H&R says its 2 inch..ill check the struts tomorrow
Old Oct 20, 2005 | 09:42 PM
J_Bones's Avatar
get aftermarket endlinks and give it a little play!
Old Oct 20, 2005 | 11:32 PM
mawreeo's Avatar
i'm just trying to help. did you make sure to lubricate the sway bar? this can cause wierd noises also.
Old Oct 21, 2005 | 05:06 AM
kung fu grip's Avatar
i have to agree, it sounds like your swaybar is binding.
what wheel size/offset are you running?
also, have you tightened all the strut mounting points, including the center nut?
Old Oct 21, 2005 | 06:00 AM
AP Kreuzer's Avatar
Default Re: (kung fu grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mawreeo &raquo;</TD></TR><TR><TD CLASS="quote">i'm just trying to help. did you make sure to lubricate the sway bar? this can cause wierd noises also.</TD></TR></TABLE>
sure did i use the stuff progress gave...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kung fu grip &raquo;</TD></TR><TR><TD CLASS="quote">i have to agree, it sounds like your swaybar is binding.
also, have you tightened all the strut mounting points, including the center nut?</TD></TR></TABLE>
im rollon on civic ex steelies, imma tighten up the top struts today
Old Oct 22, 2005 | 08:19 AM
ojay's Avatar
Default Re: (KnightHawkEP)
grease the bushings?
tighten the endlinks?
is the bar hitting the exhaust?
are the struts/springs indexed?
Blacknight117
Suspension & Brakes
10
Sep 3, 2012 08:37 AM
LatinEM2
Honda Civic (2001 - 2005)
Oct 14, 2008 09:38 AM
premo_si
Aug 8, 2006 10:38 PM
fubar
Sep 16, 2002 01:02 PM
Gennady
Jan 11, 2002 05:30 PM
