B20z/vtec Header for under 600!!!!!!!
Old Oct 20, 2005 | 12:37 AM
rex_racer728's Avatar
Default B20z/vtec Header for under 600!!!!!!!
So searched and found a bunch of questions about "What header for under 600" But I didn't see anything about a header for the b20. So what would be ideal header for under 600 for a b20z with a gsr head. It is so choked right know. i got a DC 4-2-1 with a stock cat(not hollowed) and stock exhaust. I bought the car with these parts on it but built the B20/vtec later on and now it is just choked. So for exhaust I was going to go with the Apexi WS2 and a 2.5 inlet 2.5 oulet high flow cat. Just wondering what header would give the best gains with some ground clearance. Thanks for the help.
Old Oct 20, 2005 | 05:38 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: B20z/vtec Header for under 600!!!!!!! (rex_racer728)
anr compact or rmf narrow
Old Oct 20, 2005 | 06:09 AM
Rollo Lawson's Avatar
edelbrock pro-flow w/2.5" collector mod makes sick power for the price.
Old Oct 20, 2005 | 07:19 AM
Default Re: (B16C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">edelbrock pro-flow w/2.5" collector mod makes sick power for the price.</TD></TR></TABLE>
Its an excellent header, but the ground clearance sucks
Old Oct 20, 2005 | 08:49 AM
Default Re: (PURPLETERROR aka BIGMATT)
Okay so are these the headers that your refering to???
http://www.kteller.com/store/i...1_233
What is the difference between the two compact headers. One has a merge and one has a stamp?? What is the difference between a merge and stamp collecter??? Do these come with the 2.5 outlet and flange or do you buy a flange??? Good Power Numbers???? What is better for my setup (standard or compact) I dont' mind losing a/c or p/s. I love the way it looks. Just let me know some details about the header!!! Thanks
Modified by rex_racer728 at 10:24 AM 10/20/2005
Old Oct 20, 2005 | 09:25 AM
Default Re: (rex_racer728)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex_racer728 &raquo;</TD></TR><TR><TD CLASS="quote">okay so what about this header!!!
What is the difference between the two compact headers. One has a merge and one has a stamp?? Do these come with the 2.5 outlet and flange or do you buy a flange??? Good Power Numbers????I dont' mind losing a/c or p/s. I love the way it looks. Just let me know some details about the header!!! Thanks</TD></TR></TABLE>
one has a true merge collector and makes more power because of it, it smooths the transition of the 4 primaries into the 2.5 secondary, the stamped collector will make a few less hp but is still an excellent. I run the Anr compact on my hatch, its a great header. you will have to fab a flange and a short flex piece to bolt up to your exhaust. Kteller can set you up with that also
Old Oct 20, 2005 | 10:59 AM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">
Its an excellent header, but the ground clearance sucks</TD></TR></TABLE>
what are you talking about, the edelbrock header is higher than the oil pan..???
b20vteg757
62
Feb 2, 2014 03:00 PM
90efhatch
16
Sep 14, 2011 12:36 AM
2005avtj
Jan 26, 2009 03:15 PM
B20inDCinLBC
Sep 21, 2006 05:02 PM
bambam
15
Jul 5, 2004 02:36 PM
