98 honda prelude automatic tranny problem ??
Old Oct 19, 2005 | 11:02 PM
ahs1219's Avatar
Default 98 honda prelude automatic tranny problem ??
hi
i just bought 98 prelude thats automatic. and it jerk when shifting gears (lag going thru gears) anyone know whats going on ? i just bought it to penz oil to do tranmission flush its doesnt jerk as much. but wen i stop i can still feel little jerk. later on i wen home . parked outside my house den i move in to the garage and the engine light is on .. anyone help me ??
thanks for reading.
Old Oct 20, 2005 | 08:40 AM
K-Spec's Avatar
Default Re: 98 honda prelude automatic tranny problem ?? (ahs1219)
Is your "D" light blinking? What code are you getting from the CEL?
Old Oct 20, 2005 | 02:46 PM
ahs1219's Avatar
Default Re: 98 honda prelude automatic tranny problem ?? (khalal538)
no my d light not blinking.
Old Oct 20, 2005 | 06:32 PM
'97ludetuner's Avatar
my only suggestion....get a standard
Old Oct 20, 2005 | 06:46 PM
djoreyo's Avatar
Default Re: 98 honda prelude automatic tranny problem ?? ('97ludetuner)
I had a Automatic in my 99 base model prelude and now i finally swaped it to a standard.. i blow 2 automatics before i did. sounds like your tranny is ready to go.. both of my trannies lagged and jerked right before they started to slip are not go in gear at all. The automatic prelude tranny sucks ***... if you drive it hard are just use the sport shifter sometimes just to have alittle fun your tranny is gonna start acting up before you know it... and i yea. My D light never blinked at all.
Old Oct 21, 2005 | 01:14 AM
K-Spec's Avatar
Default Re: ahs1219
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">What code are you getting from the CEL?</TD></TR></TABLE>
Old Oct 22, 2005 | 08:29 PM
ahs1219's Avatar
whats standard ??? manual tranny ??
Old Oct 22, 2005 | 08:31 PM
ahs1219's Avatar
Default Re: ahs1219 (khalal538)
i just did penz oil to do automatic tranmission flush it did help alot it doesnt jerk no more but i still feel little lagging shift. wen it go "R" i feel the grind
Old Oct 22, 2005 | 08:32 PM
ahs1219's Avatar
i havent seen the code but the mechanic erase the engine check light. and it havent been on ever since. he said something on the first valve. he told me go for a tune up.
Old Oct 23, 2005 | 10:14 AM
djoreyo's Avatar
Default Re: ahs1219 (ahs1219)
First of all.. Standard is a Manual Transmission.
Second of all.. Changing the tranny oil does help alittle. But does not fix the problem.
Third of all.. Believe me. Start saving money for a transmission. you can still drive your car and can still get a few more thousand miles on it before it blows. I know.. i messed up alot of them.
Old Oct 23, 2005 | 10:17 AM
djoreyo's Avatar
Default Re: ahs1219 (djoreyo)
The automatic transmission in the 97-01 preludes was for from being a good and relieable transmission. almost everybody i know has had a automatic has had problems with it before and have changed the transmission.
Old Oct 24, 2005 | 05:28 PM
ahs1219's Avatar
i seee thanks
Old Oct 24, 2005 | 05:43 PM
prelude1897's Avatar
First mistake you made was buying an Automatic....All Prelude automatics suck, and will have problems down the line.....The best thing you can do now is to sell that Prelude and find a 5spd.
Old Oct 24, 2005 | 05:54 PM
CBR's Avatar
CBR
Default Re: ahs1219 (prelude1897)
Lemme guess, I bet they put in regular DEX III fluid. Pull out the dipstick and sniff it...see if it smells like DEX ATF, should also be very red in color.
Honda automatics require the use of HONDA ATF, has no smell whatsoever! It's more of synthetic blend and a lighter shade of red in color.
The dealer is the only place that has it, unless you live in MN.
I think they're like $5.00/qt. You'll need 3 of them to fill it up.
If you have simple hand tools, it is very easy to do. Drain the trans, clean the magnetic drain plug, put it back in. Then look at the top of the trans, you should see what also looks like a drain plug, remove that and fill from that hole. (If you can't find that plug, you can fill it from the dipstick hole.) Check the trans fluid level with the car car warmed up and turned off. Park the car on a level surface and check the dipstick.
Hope this helps...good luck.
Old Oct 24, 2005 | 07:08 PM
ahs1219's Avatar
Default Re: ahs1219 (CBR)
it was from penzoil haha i think it was red while i was lookin at em doing it . and they use water to flush it i think some kind of holes to flush it i think i will go dealer to get some tranmission oil haha thanks man
Old Oct 25, 2005 | 09:20 PM
CBR's Avatar
CBR
I'm sure they didn't use water to flush it...I'd be very concerned if they did!!!
Get the HONDA ATF fluid and you'll be ok.
Old Oct 26, 2005 | 01:10 AM
ahs1219's Avatar
Default Re: (CBR)
im not sure lol its little holes that flushes it
Old Oct 26, 2005 | 01:11 AM
ahs1219's Avatar
Default Re: (ahs1219)
i have ob2 ecu reader the code pop up saying P1399 or P1339 i didnt really look at it cause i was driving then i turn off my engine den it was gone.
Old Oct 26, 2005 | 04:41 AM
doctorcarta's Avatar
i have a 98 auto as well and mine shifts pretty quick/hard but i receieve no engine lights...i think this is just a aggresive tranny for a sports car.
Old Oct 26, 2005 | 04:42 AM
you recommend a different automatic tranny?
Old Oct 26, 2005 | 04:44 AM
you have any links or info on auto to 5spd swap?Thanks
Old Oct 26, 2005 | 10:37 AM
mkazm83's Avatar
Default Re: ahs1219 (doctorcarta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doctorcarta &raquo;</TD></TR><TR><TD CLASS="quote">you have any links or info on auto to 5spd swap?Thanks</TD></TR></TABLE>
http://www.superhonda.com/foru...87099
Old Oct 26, 2005 | 11:02 AM
K-Spec's Avatar
yes, here is the link
http://www.mazmo.com/zameoj/swap.htm
Old Oct 27, 2005 | 12:02 AM
ahs1219's Avatar
anyone know where can i find another tranny
Old Oct 27, 2005 | 07:24 PM
djoreyo's Avatar
If there is any import shop that works on honda's as for as performance and turbo chargers. i would check there. They usually have some used ones in pretty good shape are can get one for you. A new are rebuild one usually is pretty expensive for the prelude.
