question about the crx si...
when i use my vaccum assembly, do i need both minature canisters that are attached to the map sensor(one is the purge solenoid????, and i don't know the other) cause my frien is only using one on his dx and his vaccum is fine. i have a b16a in my crix.
thanks for your help
One should be your MAP sensor and one should be the purge solenoid. Which "canisters" are you speaking of- you don't have a CAL/50state model do you? IS your map sensor mounted in a black box or just to the firewall?
i have 2 canisters that look the same(one of which is the purge solenoid) and i have the map sensor connected to the same assembly. i can only figure the map and the purge into the picture
ExVtec
Oct 16, 2008 10:48 PM
