TPS sensor and gasket
So my car is now throwing a TPS code. Will any honda/acura TPS fit my car (d16y7 auto)? I've searched but no one was really sure. Also, if honda doesnt sell a new gasket for it seperate, is it ok to reuse the old one?
the TPS is located on the opposite side of the throttle cable, correct? the one on the back is the MAP?
BTW - if the gasket is messed up, can I buy a new gastket for it from Honda? Im thinking they dont even sell those cause they dont sell TPS sensors by themselves.
Modified by deviant1 at 7:26 PM 10/19/2005
you can adjust the TPS by moving it slightly(clockwise or counterclockwise).
you need to put the multimeter needle in the Middle wire and the other to a ground, I usually ground it straight to the battery.
drewboy
11
May 16, 2005 10:44 AM
