should i mill the head?
Old Oct 19, 2005 | 01:53 PM
RACEPAK's Avatar
Default should i mill the head?
hello everybody.
im rebuilding a b16a2 for boost. (9.1 pistons/eagle rods arp studs ect ect)
now, i checked the head surface with a stright edge ruler and a feeler gauge all around it horizontal/vertical and diagonal ,even the thinest leaf (005 i think) didnt got under the ruler, so there is no clearance at all .
but a few friends told me that i should mill it anyway and now im fustrated.
what should i do?
thanks.
Old Oct 19, 2005 | 01:58 PM
B16CRXT's Avatar
Default Re: should i mill the head? (RACEPAK)
If it is flat, then why in teh hell would you want to mill it? Especially when you are going to boost it. It already has a 10:1 compression ratio. milling it will make it higher and more prone to detonation. do not mill it unless it needs to be and you are going all motor.
goldsS2000
Honda S2000
11
May 21, 2010 08:55 AM
tremblay
Oct 27, 2009 05:03 PM
Type R 00
Jan 26, 2007 06:42 PM
LD_EGSICK
Dec 15, 2003 02:13 PM
