Need 88-91 suspension suggesstions (autox & road race)
Old Mar 6, 2002 | 12:10 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Need 88-91 suspension suggesstions (autox & road race)
Right now im running on skunk2 400f/300r and koni adjs, with no sways as of yet. I compete (well try to ) in SM SoloII class, and im not sure if this is the best budget setup for me. I was thinking of making the switch to progress sport springs, as ive read alot of good things about them. Im sure they will work ok for autox, but what about road racing, which i also plan to do alot of (not competing, just open track days when i can come across them, usually 2-3 a year). Also, will the added weight up front with the b16 be a factor in the way the progress' react?
Heres a pic of me at this last weeks SFR autox
The Tires im running are Advan A032R in 185/60 14 on 91 CRX si wheels. (not pictured)
Any suggesstions are welcome!!
Thanks!
-Todd
Old Mar 6, 2002 | 12:14 PM
keithv's Avatar
Default Re: Need 88-91 suspension suggesstions (GymkhanaGTI)
i run 450f/400r eibach springs on gc coilovers with koni yellows (adjustable). the civic si comes with a rear sway, stock, so i haven't up graded that yet. the spring rate combo works well.
this combo works decent on the auto-x track, but i will probably switch the front and rear springs soon to get a little more rotation. you might want to try switching your front and rear springs to get the higher rates in the back.
not sure about road racing yet, as i haven't done it yet myself...
Old Mar 6, 2002 | 02:12 PM
xtrafastcivic's Avatar
Default Re: Need 88-91 suspension suggesstions (breaka_1_9)
tein's HA and if you want switch it to RA springs
Old Mar 6, 2002 | 03:23 PM
Count Blah's Avatar
Default Re: Need 88-91 suspension suggesstions (XtraFastCRX)
Those are not budget
Im sticking with the konis, just need a spring recommendation...
-Todd
Old Mar 6, 2002 | 04:00 PM
Count Blah's Avatar
Has anyone tried these yet?
http://www.eibach.com/roadrace.htm
-Todd
Old Mar 6, 2002 | 04:12 PM
SmokyMtnRex's Avatar
New User
Right now I am running the Tokico Blue Shocks, Neuspeed Green Springs (.8 Drop), Neuspeed 22mm rear sway bar, neuspeed front strut bar, and urathane bushings. I ran this setup this last weekend and it handled great. You wouldn't believe how tight everything is.
Old Mar 6, 2002 | 05:21 PM
Driven's Avatar
Avoid these coilovers at all cost (no pun intended).
just buy a rear suspension techniques sway bar and run with the front bar disconnected when you autocross. When you road race, connect it and run that way. good luck
Old Mar 6, 2002 | 06:32 PM
JDM_DOHC_SiR's Avatar
New User
I use 500 in front and 425 in the rear with the CR-X but I have a very high valve rate in the rear ..but the car is Very neutral...more than likely go to 600 front and 550 in the rear soon
Old Mar 6, 2002 | 07:12 PM
SpoonPL's Avatar
Default Re: Need 88-91 suspension suggesstions (JDM_DOHC_SiR)
The top racers in my club use H&R race combined with Konis. This will be my new setup this summer.
One guy crx had some Tein and a built b16 that had around 200 hp and the other has a d16 crx with bolt ons, H&R race and Konis. The b16 managed to be first of the 2 with a 2 second advance over the D16 on a 90 secondes course. It was also on a fast course.
The advantage over coilovers is the simplicity, no need to corner weight, no need to swap coils on different course. The spring rates of the H&R are more versatile.
PL
Old Mar 6, 2002 | 07:59 PM
Lt. Dan's Avatar
Default Re: Need 88-91 suspension suggesstions (SpoonPL)
I'm halfway through getting the parts for my setup.... GC's 500 front, 600 rear.. ADDCO rear swaybar... Koni adjustables... should handle very nicely...
Dan
Old Mar 6, 2002 | 09:53 PM
RyanR's Avatar
I'm selling a used set of Tein HA's with aluminum upper pillow mounts. Used for about 4 months, $900 shipped.
jasoncmps@gmail.com
Suspension & Brakes
Feb 19, 2010 08:02 AM
SloA$$ DA
19
Apr 27, 2006 08:36 AM
AznMTboy
Jul 2, 2005 01:34 AM
CaponeGotti
Jun 17, 2005 02:20 PM
BuBBa y0!
Oct 9, 2003 02:56 PM
