Possible to use INNER gsr valve springs with exhaust valve springs?
Old Oct 19, 2005 | 10:25 AM
alfee's Avatar
Default Possible to use INNER gsr valve springs with exhaust valve springs?
Like the topic says, I'm wondering if its okay or beneficial for that matter to use an extra set of INNER gsr intake valve springs with my stock gsr exhaust valve springs?
Ran a quick search but got 50/50 answers... anyone with experience that can give me a definite YES or NO answer?? thanks btw, this is for an all stock gsr head on a fully built RS Machine 2.0 gsr turbo block 9.1compression.
Old Oct 19, 2005 | 02:21 PM
non-VTEC's Avatar
Default Re: Possible to use INNER gsr valve springs with exhaust valve springs? (alfee)
im sure you will be fine within the stock rev-limits.
or it might just be better to buy a complete set of portflow inner valve springs for that added insurance.
http://www.portflow.com
Old Oct 19, 2005 | 04:10 PM
gsrious's Avatar
**not to hijack your thread, but to give more reasoning...
are the gsr exhaust valve springs(only outter ones) stronger than the intake valve springs(outter ones)?
i would understand your reasoning in swapping out the inner valve springs from the intake to the exhaust, but why not just swap out both intake valve springs(inner and outter) to the exhaust side?
Old Oct 20, 2005 | 08:13 AM
alfee's Avatar
Default Re: (gsrious)
well i have two sets of both intake and exhaust valve springs and was just wondering, whats the strongest settup. Using both sets of intake springs for the head as intake and exhaust or keep the stock settup and just add the extra set of inner intake springs to the exhaust side???
Old Oct 23, 2005 | 05:14 PM
gsrious's Avatar
use both (sets of intake springs) as inteake and exhaust springs
Old Oct 23, 2005 | 07:46 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">use both (sets of intake springs) as inteake and exhaust springs</TD></TR></TABLE>
valve is bigger on the intake, hence the stiffness difference.
Old Oct 24, 2005 | 05:00 PM
vtecmissle's Avatar
i believe the exhaust outer is stiffer than the gsr outer. The intakes together should do you well but intake inner and exhaust outer will be stiffer.
Old Oct 24, 2005 | 05:20 PM
mmuller's Avatar
Mad Scientist
Default Re: (vtecmissle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">i believe the exhaust outer is stiffer than the gsr outer. The intakes together should do you well but intake inner and exhaust outer will be stiffer.</TD></TR></TABLE>
i think your mistaken. for example gsr intke springs are the p73 exhaust.
intake springs = stiffer
Old Oct 25, 2005 | 12:34 PM
vtecmissle's Avatar
Default Re: (mmuller)
Both springs on the gsr intake are stiffer as a whole compared to 1 exhaust. Itr springs are different. I dont know about them i believe thats what you mean by springs. The gsr exhaust outer by my machinist definition is stiffer than the intake outer, but not the intake outer and inner. I actually used my intakes on my exhaust valves and bought another set of intake valves.
Old Oct 25, 2005 | 05:13 PM
alfee's Avatar
ok, what i've done is keep my intake inner and outters in tact and threw in my extra set of intake inners onto my exhaust outters. so as it is now, they're all dual valvesprings. is this settup sufficient for roughly 18psi or 380+hp of boost? correctly tuned w/ chrome on the dyno... just a safety issue due to the fact that i already blew my first boosted settup.
i appreciate all input folks
Old Oct 26, 2005 | 11:47 AM
vtecmissle's Avatar
Default Re: (alfee)
Just dont mechanical overrev the motor and you will be ok.
denraweb
Jun 5, 2011 12:57 PM
92db2gs-r
Feb 27, 2011 03:54 PM
Fat Chick Magnet
Dec 17, 2006 11:26 PM
T_bones
Feb 14, 2006 02:51 PM
lo0nY
Feb 10, 2004 10:08 PM
