PASSPORT / ACURA SLX wheels and tires forsale CHICAGO area
Old Oct 19, 2005 | 09:17 AM
TurboT's Avatar
Default PASSPORT / ACURA SLX wheels and tires forsale CHICAGO area
SET#1 -
ENKEI RT6 Wheels 18" -
Wheels are 18x8.5 in size, center bore of 108mm, center caps included
Bolt size is 6 x 139.7 or 6 x 5.5.
Offset is 0mm.
Tires are Vogue Custom Built 285/60/18, tires were $175 each
tires have 8/32 of thread left
wheels have a couple small imperfections in the clearcoat, you need to up close to see them.
Paint nicks have been touched up using touch up paint. one wheel has a 3" light curbing.
Wheels were $800+ new
$325
SET#2 -
GARA 17" Wheels
wheels are 17x8 in size, center bore of 108mm, center caps included
Offset if 0mm.
wheels have small nics from road debris, they can easily be touched up using touch up paint. no curbing. center cap key included.
These wheels have tires mounted on them.
The tires are 255/60/17 Dunlop SP5000 tires. they have about 40% life left.
Wheels were $550 new
$225
SET #3 -
MB MOTORING Razor Wheels
18x8.5 wheels
Offset = +25mm
Bolt Pattern = 6 lugs 5.5 pattern (139.7mm)
Bore Size = 4.25 inches (108mm)
Silver / Clearcoated
EXCELLENT! condition
tires were mounted, but not used.
some very small surface scuffs on the edge from being in boxes.
no tires, but includes valve stems and center caps
These go for $640 new at Discount Tire.
$325
TIRES -
General Ameritrac TR
Less than 2000 miles
They are almost NEW! Perfect for impending SNOW!
$82 each NEW at TireRack.
Manufacturer's Specifications -
Size -------------------------------- 255/70 SR17
Service Description --------------- 110S
Load Rating ------------------------ SL
UTQG ------------------------------- 500 A B
Max Load --------------------------- 2337 lbs.
Max Inflation Press. --------------- 44 psi
Tread Depth Tire ------------------ 14/32"
Weight ------------------------------ 39 lbs.
Rim Width Range ------------------ 6.5-8.5"
Meas. Rim Width ------------------- 7.5"
Sect. Width ------------------------- 10.2"
Overall Diam. ---------------------- 31.1"
Revs Per Mile ----------------------- 668
http://www.tirerack.com/tires/tires.jsp?ti...el=AmeriTrac+TR
$200
GARAs
Enkeis
MB Motoring Wheels -
jdmpimp
Jul 12, 2010 08:33 AM
nastyek9
Mid-Atlantic (Sales)
Jan 15, 2008 09:43 AM
00BLKGSR4678
Dec 14, 2005 06:48 PM
civic_tuned
Aug 9, 2004 10:31 AM
