header problems? help
i have a 89 civic hb with a 00 b16 swap, i bought a header for a b16 and it hangs to low? i cant drop it to the ground cause it will grind. i can't just cut the header cause it is 4 to 1 and it will be a mess. So if any one can give me a good site to get a nice one cheap or even some real help hook me up
if they are off of back order, this is the header that hasport sells for the obdo b16 swap in an ef. you might also want to check the ef forum as well.
http://www.hasport.com/Products/Headers.htm
bayron
Nov 5, 2008 11:25 AM
