Dropping B18A into EF Sedan w/ A/C & Power steering...which mount kit to use????
Old Oct 19, 2005 | 08:15 AM
1JDMDOMINICAN's Avatar
Default Dropping B18A into EF Sedan w/ A/C & Power steering...which mount kit to use????
Like the post says, I am attempting to drop a B18A1 into a 90 Civic EX....I want to be able to keep the A/C and PS on the car...Is it possible? Whic mount kit can i use or which mounts from the Integra and Civic can I use so that there is not that harsh vibration distributed throughtout the whole when u use a mount kit?
Also, if the car is an EX, do I still need the resistor box from the Integra?
Thanx!
P.S. The car is OBD0 and the engine is from a 92 Integra...OBD1, if that helps.
Old Oct 19, 2005 | 09:08 AM
vtecn8ive's Avatar
Default Re: Dropping B18A into EF Sedan w/ A/C & Power steering...which mount kit to use???? (mugenda6)
really any b-series mount kit
You'll need b-series a/c mount though.
PS I am not sure if the EX has the PS lines going to the Speedo. No biggie, the integra however does.
Probably just use the b18a1 p/s.
In order to use the motor you'll need to either make it obdo (changing dizzy to obdo, alternator and fuel injectors unless you convert your wiring to work with the fuel injectors).
If you stay obdo you'lll need a pr4 obdo ecu or use your EX ecu but it won't run the best but it'll run!!
Old Oct 20, 2005 | 06:33 AM
oh, ok...but its possible to keep the A/C and Power steering then...see it not my car...its my sister's car, but she wants to do a swap and keep her stuff.
Old Oct 20, 2005 | 06:42 AM
vtecn8ive's Avatar
Default Re: (mugenda6)
A/c yes. And I believe so for the p/s but i have never done this. B18a1 came with p/s (at least some of them) so I would think you could use that pump. but I am not sure with the hasport a/c mount if it'll affect the p/s pump at all.
-Shane
Old Oct 20, 2005 | 07:06 AM
CO_RaceFab's Avatar
good solid mounts for cheap http://www.pfispeed.com I work there and I use the mounts in my race car they work great never come loose and never worry about bushings save time and money buy from us $175.00 call me at the shop PFI 1-970-377-2216 Ryan
Old Oct 20, 2005 | 07:13 AM
drdisco69's Avatar
Default Re: (PFI_NAYR_ONE)
Thanks for that sales pitch, trial user guy who is not a sponsor and not in the classifieds.
Old Oct 22, 2005 | 07:16 AM
so as long as I have the mount kit...it should be a straight forward swap...correct? and i shoul dbe able to keep the A/C and PS.
Old Oct 22, 2005 | 08:53 AM
Change's Avatar
http://www.wwwefcivicsedan.kazorum.com
the ef sedan resource.
Old Oct 24, 2005 | 03:55 PM
CO_RaceFab's Avatar
yea you can keep you power steering and ac
but you still have to bang the frame rail to make room for the alternator
P.S. to drdisco69 if your going to be a **** dont talk to me. Oh yea and Ive had many honda-tech accounts so TRIAL USER.....
not really
CRX7
Jan 3, 2006 10:19 PM
brian g
Sep 8, 2005 10:27 PM
Nisif
Jul 8, 2005 11:10 PM
Unknown Member
May 4, 2003 01:49 PM
eg4sheezy
Apr 6, 2003 06:08 PM
