quick question on crx to eg rear disk swap
im looking at a crx vtec at my work that is for sale, comes with a b16, and i also noticed the rear disk brakes... i've been wanting to do a rear disk swap and the only salvage yard where i could find another civic with rear disks wanted a total of 320euros~350+us$
thats ridiculous, so i was wondering if the rear arm assembly from theh crx would be a direct/little modification fit on my 92 hatch
of course gettin the crx would also mean gettin a b16, the sweet interior, and anything else that swaps over
thanks
thanks
'90-91 CRX Si rear discs and calipers are the same as all the other 9.5" rear discs for double-wishbone Civic/Integra/CRX/del Sol. The hub assemblies will bolt right onto your trailing arms. You could also swap the entire trailing arms, though I would keep the TAs that have better/newer bushings. You will need to buy a set of e-brake cables for a '92-95 Civic Si 3dr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">'90-91 CRX Si rear discs and calipers are the same as all the other 9.5" rear discs for double-wishbone Civic/Integra/CRX/del Sol. The hub assemblies will bolt right onto your trailing arms. You could also swap the entire trailing arms, though I would keep the TAs that have better/newer bushings. You will need to buy a set of e-brake cables for a '92-95 Civic Si 3dr.</TD></TR></TABLE>i really dont know what year it is, but its a CRX 1.6vt
as for the bushings i would get all new ones, my hatch is a 92 and it sat out for a couple years before i bought it and the CRX has been sitting there for quite a while now
and whats the difference between my e-brake cables(vx) and the si's??
...as for the bushings i would get all new ones, my hatch is a 92 and it sat out for a couple years before i bought it and the CRX has been sitting there for quite a while now
