Manual to Power 90-93 Integra
Old Oct 18, 2005 | 11:44 PM
DA808TWITCH's Avatar
Default Manual to Power 90-93 Integra
I have a 1990 RS that has manual windows and locks, but I have two 1992 LS doors sitting in my garage that have power windows and power locks. Would it be possible for me to swap the doors? If so, how would I run power to the devices, and would I run into any problems?
Old Oct 19, 2005 | 05:35 AM
projectTeG's Avatar
i did the same swap but mine was with ls door, not gs doors like your have. but my plugged right in because i swap all of my 93 wireing harnesses into my 91 integra. im wanting to say that the rs aready has the wires ran. im not sure. if they arent you can more than likely find the wiring diagram in a manual and hardwire.
Old Oct 19, 2005 | 08:24 AM
blakezilla06's Avatar
Default Re: (projectTeG)
they should fit my friend did a power lock door swap with a manny door! and it was like a 2 year dif...Do some research!
Old Oct 19, 2005 | 10:53 AM
ricebucket's Avatar
Default Re: Manual to Power 90-93 Integra (DA808TWITCH)
Like projetTEG saids, if the RS already have all the wires ran then you are in heaven. If not it's gonna take a bit more work.
Try and check your fuse box, that's where I would run the power, you would want a fuse also.
Old Oct 19, 2005 | 06:15 PM
My RS has no power anything on the doors yet there is a fat wire harness going into the door from in my car...what could that be?
Old Oct 19, 2005 | 10:32 PM
projectTeG's Avatar
Default Re: (DA808TWITCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA808TWITCH &raquo;</TD></TR><TR><TD CLASS="quote">My RS has no power anything on the doors yet there is a fat wire harness going into the door from in my car...what could that be?</TD></TR></TABLE>
look in your fuse box, you might have the power window wores ran, i dont think honda made 4 different wireing harnesses for the same car.
Old Oct 20, 2005 | 04:35 AM
Thanks guys for all your help, I really appreciate it! I was just hoping that I could get a deffinite answer from someone that has already done it. The thing is that doors do not come cheap, and if I did decide to buy doors on the assumption that I could just "Plug and Play" and then find out other wise, I'm just gonna be one sad, broke, guy with two useless doors.
Gavint52
29
May 19, 2016 11:31 PM
DOHChatchGUY
Dec 8, 2013 07:29 AM
Nickboxer7
Apr 18, 2008 08:32 PM
Glen Tennis
13
Feb 27, 2007 08:26 AM
