GSR Mounts on B16 motor?? Will it work.
Old Oct 18, 2005 | 08:50 PM
solk1dd's Avatar
Default Driver Side GSR Mount on B16 motor?? Will it work.
I have a 94 EG and I'm swapping a b16 motor.
I have GSR mounts, will it work if I change the bracket bolted to the motor?
will the GSR driver side mount bracket fit on a B16 motor? so I can you the driver side GSR mount.
Old Oct 18, 2005 | 09:56 PM
airshifter's Avatar
yes
b-series mounts are interchangeable
u will have to change the bracket that bolts behind the timing cover(remove crank pulley&cover)
hellajdm333
Feb 5, 2010 11:58 AM
EM1 Resto
Sep 24, 2009 01:28 PM
vestalfootball72
Jan 20, 2007 05:28 PM
hialeahzbg
Apr 3, 2005 07:34 PM
