Rod bolt size
Old Oct 18, 2005 | 07:52 PM
psegs80's Avatar
Default Rod bolt size
Are the rod bolts on a b18b 8mm or 9mm?
Thanks
Old Oct 18, 2005 | 08:25 PM
whoneedzvtec's Avatar
Default Re: Rod bolt size (psegs80)
i believe they are 10 mm. not 100% on that one but pretty sure.
Old Oct 18, 2005 | 08:27 PM
IN VTEC's Avatar
8mm
Old Oct 18, 2005 | 09:29 PM
Default Re: Rod bolt size (IN VTEC)
hmmm. i thought sohc head bolts were 8mm and dohc's were 10mm, guess im wrong.
Old Oct 19, 2005 | 04:56 AM
psegs80's Avatar
Default Re: Rod bolt size (dc2ls-t)
ya dohc are 9mmm I found and the b18b, as well as the sohc are 8mm
Thanks guys!!
Old Oct 19, 2005 | 06:44 AM
shamoo's Avatar
Will you make something up for me please?
Looking in my Helms here:
B18B1 is an 8 x 0.75mm
B18C1 is an 9 x 0.75mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">ya dohc are 9mmm I found and the b18b, as well as the sohc are 8mm
Thanks guys!!</TD></TR></TABLE>
You must mean DOHC VTEC and DOHC Non-VTEC, right? There are no USDM SOHC Integras.
Old Oct 19, 2005 | 10:41 AM
psegs80's Avatar
Default Re: Rod bolt size (shamoo)
Ya I was trying to say b18b and sohc have 8mm and dohc vtec have 9mm!!
Thanks for making sure I understood LOL
Listen, I have all my parts but I missing p30 pistons...you know where i can get some???
Old Oct 19, 2005 | 10:54 AM
95lstegman's Avatar
$250 w/ rings from dealership (aka stealership) w/ discount. well, that's the USDM i think PR3, not P30, but they're close.
Old Oct 19, 2005 | 10:57 AM
ricebucket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ls-t &raquo;</TD></TR><TR><TD CLASS="quote">hmmm. i thought sohc head bolts were 8mm and dohc's were 10mm, guess im wrong.</TD></TR></TABLE>
Yes you are wrong...head bolts are much thicker on both application.
Old Oct 19, 2005 | 10:59 AM
psegs80's Avatar
Default Re: Rod bolt size (95lstegman)
Keep talking...and how do I get my hands on this deal???
Old Oct 19, 2005 | 11:00 AM
psegs80's Avatar
ya I know head bolts are bigger but I we where talking about rod bolts!!
Thanks thow!!!
Old Oct 19, 2005 | 11:45 AM
psegs80's Avatar
What's the deal with putting ctr pisotns on my ls rods??? What will my compression be (b18b engine) and are the std size ctr pisotns +.25???
I can get ctr pistons but I don't know if I shouldvs. the p30?
Thanks!!
Old Oct 19, 2005 | 01:56 PM
95lstegman's Avatar
no, you can't put PCT pistons in your LS. (PCT=Civic Type-R Pistons). i mean yes, technically you can, but if you have to ask if it will fit, you probably won't be able to use them. the static compression ratio comes out to about 11.8:1. so basically unless you have some pretty large cams and a very competent tuner, you don't want these. go with PR3 or P30, or go with ITR pistons either P73-00 or P73-A0. there, your pick of 4 different c/r's, and the ITR pistons come with the molybdenum-based anti-friction skirt coating, too.
CivicCxRacer93
103
Dec 8, 2004 02:17 PM
C-RICKS
23
Oct 11, 2004 08:05 AM
DjFreeze
33
Jan 10, 2003 07:38 PM
