FS:IPOD speakers
Technical data
* Compatible iPods: Any docking iPod can dock in the unit (regardless of storage capacity), while non-docking and Mini iPods can plug in through the auxiliary audio input
* Continuous power: 2 watts per channel (into 8 ohms with 10 percent THD from 20 to 20,000 Hz)
* Frequency response: System: 60 to 20,000 Hz (no +/- range given)
* Signal-to-noise ratio: Greater than 75 dB at 1 kHz
* Drivers: Two 1-inch neodymium micro drivers per speaker
* Amplifier: Class D
* Tone controls: None
* Audio enhancements: MaxxBass technology
* Provides iPod charging: Yes (when docked)
* Batteries: 4 AA (not included)
* Battery life: Up to 24 hours of continuous playback
* Power input: AC 120V, 60 Hz
* Power consumption: DC 9V, 1.6 Amps
* Item width: 8 inches
* Item height: 5.4 inches
* Item depth: 1.2 inches (closed)
* Item weight: 15 ounces (without batteries)
* In the box: inMotion sound system, a .125-inch minijack-to-minijack stereo analog audio interconnect, a protective case, 10 GB/15 GB iPod docking spacer, a docking connector travel cover, an iPod-charging AC power adapter, a user's manual, a quick-connect card, and warranty information
Sounds pretty good for how small it is ...........
$60 or B/O
$60 or B/O
DkofBTSI
Audio / Security / Video
Mar 6, 2008 02:48 AM
