ls short block with itr pistons etc...
93 ls short block with itr oil pump, itr water pump, shotpeened rods, .25 oversized usdm itr pistons, micropolished crank, gsr timing belt. block is legit, i have the title to the car it came out of to prove it. this motor was in my car for 20k miles. this a strong motor with 250-260 compression all the way across. i also have a brand new ls headgasket i will throw in. asking $600 so cal pick up. unless you really want to pay for shipping and what not.
[Modified by Jackson, 6:51 PM 3/6/2002]
[Modified by Jackson, 10:54 PM 3/14/2002]
Just wondering why did you take it out of your car after 20k miles?
And were the ITR oil and water pumps new when installed?
Will this block work within the stock timing of my B18A system, or does it have a higher CR than stock B18B?
Thanks in Advance...
i took it out to start a new project which is in my car now. yes the oil and water pumps were new. i also used new rod and main bearings. and a new main seal. i dont know what you mean by stock timing. if you use your ls head, the cam timing will be ok, but if you decide to go ls/vtec, the timing will be off slightly. the compression with this block and a b16a head will be about 10.8:1. and with an ls head, it will be about 10.4:1.
One time, I was going to buy something from him...I gave him the money. All he did was kick me in the ***** and run away.
Bad seller!
jfwy, Jackson is cool. Good guy. I vouch for him. If he rips you off, I give you permission to come to my house and kick me in the nuts.
Bad seller!
I can vouch for him, real good guy. Also that bottom end is built right and runs real strong. Good deal, with the right head and cams this is a definite 12sec. motor.
Anyone on here ever bought from Jackson?
you still got the block? email me at impact240@aol.com
good stuff
