Need help with tranny swap in a 5th gen
Old Oct 18, 2005 | 06:30 PM
lvblkjack's Avatar
Default Need help with tranny swap in a 5th gen
I have a 2001 auto and i'm trying to do a manual swap with a T2W4. The T2W4 is coming off from a teg, which of the following parts i can use from the teg? and which ones i have to get from another 5th gen? I'm in San Diego area and looking for help if you did a swap before. Thanks.
*Clutch Slave Cylinder
*Clutch Dampener
*Vehicle Speed Sensor (VSS)
*Reverse Switch
*Hydrolic Lines
*5spd Starter
* MOST LIKELY THESE WILL BE ATTACHED TO TRANNY (DOUBLE CHECK)
Trans mounts-side
Engine Mount-rear (rear is optional-the rear auto mount will work)
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
5speed ECU
5spd Intermediate shaft (half-shaft)
Old Oct 18, 2005 | 07:01 PM
safe driver's Avatar
i would worry about figuring out a way to bolt the tranny to the block first.
Old Oct 18, 2005 | 07:14 PM
K-Spec's Avatar
Default Re: Need help with tranny swap in a 5th gen (lvblkjack)
the T2W4 came off an integra? Anyway, this is a Euro R tranny and will bolt straight up to your H22 no problem. You can use everything on that list except: brake pedal, clutch pedal, Clutch Master Cylinder, ECU, Shift Linkage, Intermediate Shaft, Trans mount-side, and clutch line. For the listed parts that you cannot use from the integra, you can get from another 5th gen lude or the dealer.
I got all mine from the dealer. Goodluck with your swap
alpinefr3ak
Dec 11, 2007 07:03 AM
Alude99
Sep 25, 2007 05:04 PM
DC2-JRSC'd
Jan 12, 2007 02:05 PM
sic95av6
Jun 28, 2004 03:56 PM
blackssvtex
Jul 6, 2003 01:39 AM
