compression for safe motor
Old Oct 18, 2005 | 05:58 PM
BLUE EH3's Avatar
Help we my pennies
Default compression for safe motor
what a good compression for daily driver for built gsr?
Old Oct 18, 2005 | 07:17 PM
Slow ass EF's Avatar
Default Re: compression for safe motor (BLUE EH3)
compression ratio is?
Engine—What is a healthy engine???
Compression test results should be as follows:
* 8:1-8.5:1 compression: 150-170 psi per cylinder
* 8.5:1~9.5:1 compression: 170-210 psi per cylinder
* 9.5:1~11:1 compression: 210-275 psi per cylinder
* 11:1+ compression: 250+ per cylinder (highly depends on cams being used)
-- from evans-tuning.com
Old Oct 22, 2005 | 03:02 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: compression for safe motor (slow *** ef)
i wanted tio what would be a good CR for my future built gsr motor DAILY driver, that i planning
Old Oct 22, 2005 | 03:32 PM
mmuller's Avatar
Mad Scientist
around high 11's i would say.
you could go a lil. higher but who needs it..
Old Oct 24, 2005 | 06:17 PM
i plan on daily driving my 11.5:1 LS/VTEC so go for it. i have a friend who daily drives his 11:1 GSR no problems
Old Oct 24, 2005 | 07:09 PM
BLUE EH3's Avatar
Help we my pennies
ok.
Old Oct 24, 2005 | 07:28 PM
DarkDragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow *** ef &raquo;</TD></TR><TR><TD CLASS="quote">compression ratio is?
-- from evans-tuning.com</TD></TR></TABLE>
if this is right then my LS has poor compression, its supposed to be 9.2-1 but when i tested it, it was 160psi across the board
Old Oct 25, 2005 | 08:29 AM
drdisco69's Avatar
Default Re: compression for safe motor (DarkDragon)
Depends entirely on the gauge and the cams. As long as it's uniform across all cylinders, you're ok. And leakdown test &gt; compression test any day.
88 civic
Apr 5, 2009 03:21 PM
maximedx
May 2, 2004 04:32 PM
stupidfast
Oct 20, 2002 03:50 PM
