QS: LSD Y1 HELP!!!
Old Oct 18, 2005 | 05:19 PM
sacjdmz's Avatar
Default QS: LSD Y1 HELP!!!
Hey guys I have a 1990 integra and I have a jdm B16A1. REcently I found out that I have a LSD tranny. My speed sensor hasn't been working for the longest time and I already did all of the diagnosis and everything works, speedo cable, speed sensor, and the gear inside the tranny to spin the speed sensor. but my speedo tach doesn't move while I'm driving. I had a discussion with a mechanic at a local shop called REDLINE PERFORMANCE. and the guy said that I need a "LSD SPEED SENSOR", because the USDM ones won't work because that teeth on the speed sensor gear is different for the JDM LSD. Does anyone know where I can find a JDM LSD Speed Sensor????
Old Oct 18, 2005 | 05:24 PM
SkRiBLaH's Avatar
Default Re: QS: LSD Y1 HELP!!! (sacjdmz)
bump///
im also looking for one.
Old Oct 19, 2005 | 07:01 AM
SkRiBLaH's Avatar
ttt
Old Oct 19, 2005 | 08:43 AM
sa90eg's Avatar
i just have a 91 usdm civic si speed sensor on my tranny and it works good
Old Oct 19, 2005 | 10:37 AM
SkRiBLaH's Avatar
Default Re: QS: LSD Y1 HELP!!! (sa90eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa90eg &raquo;</TD></TR><TR><TD CLASS="quote">i just have a 91 usdm civic si speed sensor on my tranny and it works good </TD></TR></TABLE>
can anyone confirm?
Old Oct 19, 2005 | 11:07 AM
MikeySpec's Avatar
y1 speed sensors are electronic.
Old Oct 19, 2005 | 06:00 PM
sacjdmz's Avatar
Default Re: QS: LSD Y1 HELP!!! (MikeySpec)
hey bro sa90eg says that a 91 civic speed sensor will work is that true??
Old Oct 30, 2005 | 11:49 AM
bossman032's Avatar
all the speed senors are the same.
YS1 some had lsd (only the jdm models) the pos YS1 are mostly LS trannys. Rarely you will find a YS1 USDM if thats the case its from a 92-93 GSR.
only difference is the Electronic vs Cable.
You can use a Cable speed sensor on a Hydro tranny.
Your machincs don't have a clue what they are talking about. Tell them to slap themselves!!!!
Trust me I have done it so I know
Old Oct 31, 2005 | 02:49 AM
SkRiBLaH's Avatar
Default Re: QS: LSD Y1 HELP!!! (bossman032)
sorry. thought that the actual gear had more or less teeth than a non LSD VSS gear.
but now i know theres no such thing.
Old Oct 31, 2005 | 04:30 PM
pr0honda's Avatar
Default Re: QS: LSD Y1 HELP!!! (SkRiBLaH)
you need to check inside the car where the cable goes in.. i had a problem with mine and i have seen a couple other peope who have also.. inside the dash behind the gauge cluster. the calble speed sensor will work on the y1 even though the y1 originally came with a electronic sensor.
shawn
Old Oct 31, 2005 | 06:11 PM
2quikmotorwerks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">all the speed senors are the same.
Trust me I have done it so I know </TD></TR></TABLE>hell na the lsd speed sensor gear is different then the non lsd speed sensor gear the lsd gear is smaller with a finer gear pattern , the non lsd gear is wider with a more corser gear pattern i have both sensors and will post pics later on, alot of people cram the non lsd sensor into the lsd tranny and it works but ***** **** up later on.(not recomended)
Old Oct 31, 2005 | 07:08 PM
bossman032's Avatar
Default Re: QS: LSD Y1 HELP!!! (2quikmotorwerks)
I have used the SPEED SENSOR from YS1 GSR(NO LSD) Cable tranny speed sensor on my CTR (97 Civic type R) S4C LSD tranny for a several thousand miles no problems
so expletive that didn't do nothing to my tranny!!!!! I call it BS
then I swapped Civic 99si cluster in my ef went with the S4C speed sensor no problems...
thats why I said it lol
JDMINTEGRALS
Feb 19, 2006 03:58 PM
Boosted96EK
Oct 31, 2003 12:12 PM
