Suspension & Brakes Theory, alignment, spring rates....
CRX Si rear arm bushings fit 94 Integra rear arm?
Old Oct 18, 2005 | 02:51 PM
RevinRex's Avatar
Default CRX Si rear arm bushings fit 94 Integra rear arm?
Will a set of CRX Si rear arm bushings fit on 94 Integra rear arms? Just wondering cause I know some parts are interchangeable. Also, does anyone know right off hand if the bushing has that metal insert around it on both? Thanks!
Old Oct 18, 2005 | 04:27 PM
Tyson's Avatar
Default Re: CRX Si rear arm bushings fit 94 Integra rear arm? (RevinRex)
the DC bushing may be different diameter than crx. DA is definately bigger. wes vann found that crx bushings will fit PERFECTLY inside the outer sleeve of the DA integra if you take rubber out. so youll end up with TWO sleeves, but it works.
http://www.performanceforum.co....html
Old Oct 19, 2005 | 04:41 PM
RevinRex's Avatar
Default Re: CRX Si rear arm bushings fit 94 Integra rear arm? (Tyson)
Perfect! Thanks for the info and pic.
RPM_69
Sep 29, 2007 10:50 AM
yellowjdmcrx
May 7, 2006 01:14 PM
EFOSV
Sep 4, 2005 09:36 PM
B2FiNiTY
17
Mar 25, 2004 03:17 PM
