Need help with throttle body swap
Old Mar 6, 2002 | 08:41 AM
canuck-mx6's Avatar
Default Need help with throttle body swap
I purchased a 66mm bored B16 tb so that I can swap out my OBD1 GSR TB. In the picture below, can anyone tell me what the part that is circled is....and do I need it?
I also switched to the Skunk2 mani, so I am not using the IAB and sencondary butterflies.
Old Mar 6, 2002 | 08:46 AM
whtgsr1998's Avatar
Default Re: Need help with throttle body swap (canuck-mx6)
I you'll be ok. My throttle body doesn't have that thing onthe bottom.
Where did you get your bored out Throttle body?
Old Mar 6, 2002 | 11:07 AM
delSolLS's Avatar
That appears to be the FITV. Fast Idle Thermo Valve. Newer throttle bodies don't have that valve- it is built in to the throttle body.
Old Mar 6, 2002 | 11:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Need help with throttle body swap (delSolLS)
Isn't that the thing that some people do the coolant bypass mod on?
on2wheels
Jul 15, 2007 07:17 PM
bootlegtrader
Feb 5, 2006 09:04 AM
