Almost new and complete poorman's type r setup for sale
Well the engine I was looking forward to putting in my car has got to go now.
I just totaled my car this morning and have no use for this project that I have
around 5 grand into. I would say now that I am not interested in parting it out as I have too many parts and it would take forever. Most this stuff for the swap is new, and what was used is in perfect condition. I got a lot of the parts from a couple kids that work at a Honda service center, and had their knowledge while putting this together.
Main parts:
B18C1 block- New forged SRP 11:1 compression piston with new rings, fully balanced, reconditioned rods, new race rod and main bearings. New oem honda part including oil pump, water pump, and timing belt. Have list of a few other things done to the block while it was at the machine shop and can list to anyone who is interested.
Head- PR3 head with integra type r valve springs and retainers. This is the only part of the engine that is used. BUT IT IS IN PERFECT CONDITION. I checked for warping across the head at all specifed points, and the smallest feeler gauge wouldn't fit under any part of the straight arm.
PR3 intake manifold in very good condition. Also have the hondata type manifold gasket. Bullfrog prelude size throttle body (around 65 mm) in near perfect condition. Also have stock prelude TB.
Have brand new OBX-R header 4-2-1 design- looks to have pretty good welds.
B16 valve cover that I painted red with wrinkle paint. Looks decent, but if you want perfection you would have to redo it.
New distributor king distributor. New NGK wires, and new Denso iridium spark plugs. Head has b16 cams from a 99-00 civic si very low miles.
STR billet cam seal.
Can include cheap intake system I got for free with all this if needed.
:EDIT: I forgot to mention there arp head studs holding the two together.
Transmission:
B16 hydro trans-not sure what car or year it came from.
New gearspeed synchro set (1-5 gear). First and second are brass like stock, third, fourth, and fifth and carbon coated like the new honda synchros.
When I installed these synchros, the old ones were in perfect condition, so that tranny probably has low miles too.
Integra Type R lsd- looked to be in very good condition.
And the best part of the tranny in my opinion is the integra ls fifth gear I installed.
This will let you get around 35 mpg highway and keep the engine speed down if you ever have to make road trips.
All the rest are the stock USDM integra type r gear ratios for quick accleration.
New starter motor and solenoid.
New aftermarket clutchkit with lightweight flywheel.
New axles and intermediate shaft.
Have b-series shift linkage if necessary.
New B&M short shifter with new energy suspension bushings.
also have different short shifter included that I didn't know came with the linkage.
Random stuff:
PR3 ecu.
Apex VAFC with all needed hardware. (decent condition)
New aluminum radiator. (this was actually pretty cheap, but it is thicker and not the copper fin design like stock). It does have plastic endtanks.
New B&M fuel pressure regulator. Command Flo line.
New B&M fuel pressure gauge that attaches to the fuel pump.
New Denso oxygen sensor.
also gsr fuel pump if buyer is interested.
Along with a few odds and ends you would have to pick up, all this will need is a harness, and fuel injectors and fuel rail. Also vaccum lines and a few small things like that.
I have been thinking about the price and feel if people are willing to pay over 5000
DOLLARS for a imported type r engine that they have no idea of the history or actual mileage, then 4000 or something in that area seems like a good deal for this almost new one. I would prefer people in the Salt Lake area contact me, but if anyone else is willing to come pick it up that wouldn't be a problem. I will post some pics if anyone is SERIOUSLY interested.
Thanks, and only serious offers please.
Modified by coconutsoldier at 3:31 AM 10/19/2005
Modified by coconutsoldier at 3:58 AM 10/19/2005
Main parts:
Transmission:
Random stuff:
PR3 ecu.
back up. Also, for anyone who picks this up in the Salt Lake area, I work
at a honda dealership and can get any of the parts you need almost half off.
andyman97
Oct 27, 2015 10:22 AM
TypeRMOBBiN209
Northern California (Sales)
235
Oct 24, 2012 11:45 AM
ITR.#1446
Northeast (Sales)
Jun 26, 2009 01:47 PM
ITR.#1446
Jun 26, 2009 01:34 PM
EJ1 wilcox
Jun 18, 2005 08:19 AM
