Swap Info
Old Oct 18, 2005 | 10:39 AM
PrettyLakesBoy's Avatar
Default Swap Info
Will a 98 Sohc cam drop str8 into a 93 civic?
Old Oct 18, 2005 | 10:42 AM
jameskersten1's Avatar
Ask in here is your best option....
https://honda-tech.com/zerothread?id=878010
Old Oct 18, 2005 | 10:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Swap Info (PrettyLakesBoy)
it will fit yes.
will there be things you need to do to make it work yes.
you need an obd1 dizzy, obd1 injectors, obd1 alternator. and a few others i know i am forgetting. i have a y7 in a friends delsol si we needed to get it running. we rigged the hell out of it with stuff i had laying around my shop.
Old Oct 18, 2005 | 02:52 PM
Default Re: Swap Info (boostedcivicsir)
Can i use the same mounts off of the sohc i have now....and i have to use my alternator...harness....distrubutor.....starter... ..intake manifold.....and injectors....correct?
crx-ricki
Classic Hondas
Mar 9, 2013 12:20 AM
DC206R
Mar 6, 2009 09:56 PM
civicracer94
Sep 12, 2007 12:16 AM
blindsk8er1013
Nov 4, 2006 12:10 PM
JCracer723
Oct 11, 2002 07:52 PM
