Weird noise when turning the wheel??
I have a 1999 GSR and when I turn the wheel it makes a weird noise. The best way to describe the noise is like if a seal was yelling. It sounds like how seals communicate. That's the best way to describe it. It seems to only happen when i am turning the steering wheel. Anyone heard of anything like this??? please help.. thanks again
Can you pinpoint where the noise is coming from? If it's coming from underneath the steering column/dashboard, then it's a common problem amongst 3rd gen Integras. There was a TSB to solve this problem I believe, all you have to do is lubricate the bushings and you're all set.
I still haven't gotten around to doing it.
Is your power steering fluid up to level?
I have a 99 as well and its makes like a little moaning sound when i turn the wheel,I only hear mine at low speed like when i'm parking or backing out of parking.
Chris what is that bushing exactly called....i have the same problem but its weird be cause it only happens when its cool or i turn really fast....Steering colum bushing???
dth0ng69
May 3, 2016 09:54 AM
