wiring question
Old Oct 18, 2005 | 09:47 AM
Eg6_rAcEr's Avatar
Default wiring question
well i am dropping in a b18c into my hatch and it has a skunk 2 intake manifold on it. so i was wondering if would still have to wire up the iab sensor and and the evap purge solinod. if i do can some one tell me the exat steps on how to do this? i have all ready figured out the vtec wires and the knock sensor and this is the only problem im having. soo any help would be appericated thanks
Old Oct 18, 2005 | 10:06 PM
Eg6_rAcEr's Avatar
Default Re: wiring question (Eg6_rAcEr)
no one can help me
Old Oct 19, 2005 | 09:12 AM
98 Spec R's Avatar
If you have a skunk manifold it does not have an IAB solenoid or IAB at all so there is no need to wire it up. Also, the evap purge should already be hooked up in your stock wiring. Good Luck
Old Oct 19, 2005 | 08:16 PM
Eg6_rAcEr's Avatar
Default Re: wiring question (98 Spec R)
soo it should still be wired even though i am using a si harness
CRXB16PSI10
Sep 11, 2004 03:55 AM
integmester
Jul 22, 2004 04:26 AM
SuperCivic26
Apr 16, 2003 09:26 PM
90_Civic_Hatch
Aug 6, 2002 11:52 AM
