Which cam to use??
Old Oct 18, 2005 | 06:53 AM
blacksihatch's Avatar
Default Which cam to use??
I have a SIRII head (p30) what would those cams be comparable to and if i put just the intake cam from a CTR should i see or feel gains?? Or i'am i better off useing both CTR cams.
Old Oct 18, 2005 | 11:03 AM
HONDA RR's Avatar
Default Re: Which cam to use?? (blacksihatch)
If you change your cams don't forget to upgrade your valve springs and retainer. You will notice a gain with ctr cams.
Old Oct 18, 2005 | 12:21 PM
Default Re: Which cam to use?? (HONDA RR)
i have upgraded my valve train with omni flat-valves,omni dual springs, and manley titanium retainers,and a 3 angle valve job. so shes all set ,just wondered if i could get away with changing out the intake side with a CTR cam and leave the stock exhaust cam..
SELF MADE
Nov 9, 2012 05:47 AM
JaydmEg
Mar 1, 2009 03:45 PM
endlessjdmeg
Aug 12, 2007 08:24 PM
Phatch99
Aug 10, 2004 10:31 AM
quik2kSi
Jul 27, 2002 09:39 AM
