Can you lift a cars suspension?
Old Oct 17, 2005 | 10:08 PM
a5i19's Avatar
Default Can you lift a cars suspension?
i have a 2001 honda accord ex and i put a bodykit on it currently i have 15'' alloys on it and the bodykit is barely off the ground im goin to be putting 17''s on it but i still want to lift my car a little, what can i do? and also if there is something i can do how much do u think it would cost me?
thanks everyone
Old Oct 18, 2005 | 01:30 AM
Jeremy D. Swain's Avatar
Default Re: Can you lift a cars suspension? (a5i19)
Man, honestly if you lift your car it's going to look worse than it already does. Your going to have a 5 inch gap between your tire and the fender. If you can't figure out how to carefully drive your car with the bodykit, then you should just take it off, and put your stock bumpers back on.
Old Oct 18, 2005 | 02:38 AM
LL2009's Avatar
Default Re: Can you lift a cars suspension? (Jeremy D. Swain)
I agreed with Jeremy D. Swain , option 2 you can just get coil over and lower it or raise it any time you want.
Old Oct 18, 2005 | 05:59 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a5i19 &raquo;</TD></TR><TR><TD CLASS="quote">the bodykit is barely off the ground</TD></TR></TABLE>
Then it's a crappy body kit.
What does this have to do with wheels and tires, the subject of this forum?
Old Oct 18, 2005 | 11:30 PM
fridayfred3p's Avatar
if 17s isnt the stock rim than puttin a bigger rim on the car will lift it slightly
Old Oct 19, 2005 | 02:54 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Can you lift a cars suspension? (fridayfred3p)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fridayfred3p &raquo;</TD></TR><TR><TD CLASS="quote">if 17s isnt the stock rim than puttin a bigger rim on the car will lift it slightly</TD></TR></TABLE>
Not necessarily. The ride height depends on the size of the tire, not the size of the wheel.
Midori Green
16
Aug 9, 2008 05:48 PM
EnjoyTheRideDC2
Suspension & Brakes
Feb 6, 2008 05:45 PM
riceforlife
Dec 31, 2007 02:00 AM
george34
21
Aug 2, 2005 04:37 AM
SPOON DC2
Aug 17, 2004 12:24 PM
