crower stage 2
Old Oct 17, 2005 | 08:20 PM
hytec's Avatar
Default crower stage 2
has anyone use crower s2 in there ITR,what do you think?
Old Oct 18, 2005 | 04:14 AM
xjohnx's Avatar
Default Re: crower stage 2 (hytec)
a friend of mine had them, both he and i were less than impressed.
i'd take a look at the BC stage III+'s, or Toda spec b's, depending on your budget.
Old Oct 18, 2005 | 04:35 AM
Bradstard's Avatar
I ran Crower Stage 2's on my ITR and I was pleased with them. I then changed to Toda Spec C's on the exact same setup and lost power across the entire power band. I'll see if I can find the dyno plots, they were done at P1 and tuned by Jack.
Old Oct 18, 2005 | 07:05 AM
Team Bukkake Sucks!!!'s Avatar
Default Re: crower stage 2 (Bradstard)
I <3 MY CROWERS(63413-2).... bc3+ are not on the same level as crower stage 2's...choosing a cam is mostly about where you want to make power...each brand cam has a different goal for powerband in mind
Old Oct 18, 2005 | 07:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I ran Crower Stage 2's on my ITR and I was pleased with them. I then changed to Toda Spec C's on the exact same setup and lost power across the entire power band. I'll see if I can find the dyno plots, they were done at P1 and tuned by Jack.</TD></TR></TABLE>
I hope you do...Dont know why there a lot of hating on crower
Old Oct 18, 2005 | 08:15 PM
hytec's Avatar
i am looking around the buddy spec 3 dont seen to bad.The crowers power curve looks like the type-r cams
Old Oct 18, 2005 | 09:16 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hytec &raquo;</TD></TR><TR><TD CLASS="quote">has anyone use crower s2 in there ITR,what do you think?</TD></TR></TABLE>
I think that there are better cams out there.
Old Oct 19, 2005 | 11:21 AM
Bradstard's Avatar
Here's my old thread....
https://honda-tech.com/zerothread?id=956740
This was on P1's Mustang Dyno.
Old Oct 19, 2005 | 12:01 PM
xjohnx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Here's my old thread....
I'm not terribly surprised the C's made less power than the Crowers on your setup. Don't the Spec C's pretty much need bumped compression to make respectable gains?
Old Oct 19, 2005 | 06:54 PM
b19coupe's Avatar
Default Re: crower stage 2 (xjohnx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xjohnx &raquo;</TD></TR><TR><TD CLASS="quote">I'm not terribly surprised the C's made less power than the Crowers on your setup. Don't the Spec C's pretty much need bumped compression to make respectable gains?</TD></TR></TABLE>
C's also make power pretty high. Peak at 8700 on my motor, and carry power well past 9,000. Bradstards motor was being shut down at 8,200.
Old Oct 20, 2005 | 06:20 AM
Default Re: crower stage 2 (b19coupe)
yeah the C's look like they are still climing when it was shut down the crowers started to flatten out
Old Oct 23, 2005 | 04:09 PM
hytec's Avatar
Default Re: crower stage 2 (Team Bukkake Sucks!!!)
emissionsux
30
Feb 4, 2005 06:33 AM
^AnDre^
21
Dec 13, 2004 09:36 AM
vtecman253
Aug 21, 2003 07:58 PM
JDM 007
Apr 8, 2003 10:28 PM
AllMotorITR
Jan 8, 2002 10:22 AM
