car not cranking over need help
Old Oct 17, 2005 | 08:05 PM
stubk20's Avatar
Default car not cranking over need help
I"m having trouble starting up my car. The battery winds up but it just doesn't want to start up the radio turns on and the windows still roll down though. Has anyone else had this problem before? Would the problem be from the starter or alternater?
Old Oct 17, 2005 | 08:37 PM
onefastrx7turbo's Avatar
Default Re: car not cranking over need help (stubh22a4)
ok, the battery winds up? you mean the starter? like, its cranking but not starting? check battery voltage. check for spark, check for fuel.
neil
Old Oct 17, 2005 | 08:42 PM
petern101's Avatar
Default Re: car not cranking over need help (onefastrx7turbo)
yeah many ppl have this problem
its just easier to figure out what fixes the problem once you exhaust the usual suspects like the dude above stated
Old Oct 18, 2005 | 06:40 AM
kulrevon's Avatar
Default Re: car not cranking over need help (petern101)
turn your ignition on does your check engine light go on for a sec then shut off?
If it doesnt shut off it is probably your main relay. hit me up if you do this and thats your problem.
Old Oct 18, 2005 | 06:44 AM
The Weather Man's Avatar
Three things
Fuel
Ignition
Mechanical/compression
Remember to use your 5 senses first. Thats the key to being a good tech.
Try to listen to the car - it will tell you the problem.
BLOCK8732
11
Feb 20, 2015 05:12 PM
tran1088
Acura TSX
Jan 19, 2012 11:51 AM
BlkITR01
Nov 25, 2008 09:22 AM
hurraquio
Feb 4, 2006 07:34 PM
Ponyboy
Mar 18, 2002 07:47 PM
