Brake light stays on?
Old Oct 17, 2005 | 07:35 PM
duggy's Avatar
Default Brake light stays on?
Today I was driving and parked my car at Wal-mart. Came out and noticed my brake lights are on. I'm like wtf? Press the brake no change. Check the instrument/tail light fuse and it was good and still changed it anyways. Brake lights did not turn off when I took the fuse out. Tell me what's wrong?
Is it the switch under the brake pedal?
Old Oct 17, 2005 | 07:45 PM
duggy's Avatar
Default Re: Brake light stays on? (duggy)
I searched....and found nothing.
Modified by duggy at 9:18 PM 10/17/2005
Old Oct 17, 2005 | 08:10 PM
hatchi's Avatar
what kind of car?? check your brake fluid level. if it has drum brakes check the rear wheel cylinders
Old Oct 17, 2005 | 08:13 PM
cambopheonix56's Avatar
Default Re: Brake light stays on? (hatchi)
more then likely low on break fluid.
Old Oct 17, 2005 | 08:18 PM
duggy's Avatar
So you're tellin me when the car gets low on brake fluid the lights turn on?
Old Oct 17, 2005 | 08:20 PM
polymath's Avatar
I bet you the rubber stopper on the brake pedal lever came apart...now there's nothing to depress the switch turning your lights off. I've seen it happen on several civics.
Old Oct 17, 2005 | 08:27 PM
EL Vap133's Avatar
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">So you're tellin me when the car gets low on brake fluid the lights turn on?</TD></TR></TABLE>
They are confused by your title since it says "brake light stays on".
Have you done any wiring lately?
Old Oct 17, 2005 | 08:33 PM
duggy's Avatar
Ah, I guess I didn't make it clear.
Only wiring I've done lately is change out the main relay.
I'd like to know more about this rubber stop on the pedal.
Old Oct 17, 2005 | 08:59 PM
duggy's Avatar
I'll check this in the morning.
Old Oct 18, 2005 | 07:57 AM
duggy's Avatar
Quick bump
Old Oct 18, 2005 | 08:24 AM
duggy's Avatar
Took out the switch. Put it up to an ohmeter and it had continutiy when i connected and didnt when i pressed the button. Seems to be working fine?
Old Oct 18, 2005 | 08:26 AM
JDM-EJ1's Avatar
Default Re: Brake light stays on? (Coyote1800cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coyote1800cc &raquo;</TD></TR><TR><TD CLASS="quote">I bet you the rubber stopper on the brake pedal lever came apart...now there's nothing to depress the switch turning your lights off. I've seen it happen on several civics.</TD></TR></TABLE>
This is usually what happens.
Old Oct 18, 2005 | 08:53 AM
duggy's Avatar
And it sure was. The rubber stopper just completly fell out. Oh well I ghetto rigged it but it works. Thanks guys.
phrenzykEG6
Apr 12, 2010 08:54 AM
musclehead954
Feb 27, 2008 10:28 AM
white99accordEX
Dec 22, 2005 04:08 AM
Nocturnal
Sep 24, 2005 12:23 PM
slowassR
Sep 3, 2003 08:43 AM
