question about "JDM DOHC ZC" transmission
Old Oct 17, 2005 | 05:34 PM
Bense's Avatar
Default question about "JDM DOHC ZC" transmission
i'm considering purchasing one, and i want the one with the really short gears that you can interchange with other D series transmissions. However the description for the one i am looking at says "This transmission has longer gears for better torque usage and with the equal length axles will lower torque steer problems."
I thought that there was only one JDM ZC DOHC tranny that used an intermediate shaft, are there any others?
Old Oct 17, 2005 | 05:44 PM
jlicrx's Avatar
Default Re: question about "JDM DOHC ZC" transmission (Gordon Liddy)
there is only one for the OBD0 DOHC ZC - the reason they say longer gears is that the ZC has a 3.88 final drive which is longer than the Si with 4.25 final - actually the ZC 4th and 5th are shorter than the Si when you factor in the final drive
Old Oct 17, 2005 | 05:52 PM
Bense's Avatar
Default Re: question about "JDM DOHC ZC" transmission (jlicrx)
so does that mean that it has the 1.346 3rd gear and the 1.033 4th gear?
Old Oct 17, 2005 | 06:04 PM
jlicrx's Avatar
yes and 1.944 2nd - .878 5th
Old Oct 17, 2005 | 06:08 PM
Bense's Avatar
awesome thanks
Old Oct 18, 2005 | 08:34 AM
DoHcZC91si's Avatar
when i did my dohc zc swap into my car i was planning on using the si trans but complications led me to a zc trans..as of now i love it..handels the torque great and i even got lucky enough to have one with a limited slip..some people say all the jdm zc trans had it but not sure how true it is..
Old Oct 18, 2005 | 03:55 PM
virginia_dude's Avatar
Default Re: question about "JDM DOHC ZC" transmission (DoHcZC91si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoHcZC91si &raquo;</TD></TR><TR><TD CLASS="quote">when i did my dohc zc swap into my car i was planning on using the si trans but complications led me to a zc trans..as of now i love it..handels the torque great and i even got lucky enough to have one with a limited slip..some people say all the jdm zc trans had it but not sure how true it is..</TD></TR></TABLE>
no, the LSD was optional on them....most did not have it...
Old Oct 18, 2005 | 06:00 PM
jisu009's Avatar
Default Re: question about "JDM DOHC ZC" transmission (virginia_dude)
I just built a box with a ZC 1-4 and SI 5th and 4.25 FD.
Plain and simple...it rocks.
Old Oct 18, 2005 | 06:21 PM
Default Re: question about "JDM DOHC ZC" transmission (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">I just built a box with a ZC 1-4 and SI 5th and 4.25 FD.
I went to a B16 swap before I got around to trying that one...still have the Si Box parts for the swap.....need to eBay those... my old ZC engine and tranny are residing in a fellow board members car since last year.
Old Oct 21, 2005 | 09:49 AM
TommyBB's Avatar
anybody know where to get an intermediate shaft that will work with the dohc Obd0 zc tranny??
Old Oct 21, 2005 | 12:39 PM
Kwicko's Avatar
Default Re: (TommyBB)
For an intermediate shaft that will work, your best bet is to call an importer. They usually sell for around $75-100 plus shipping (and be prepared to get raped on shipping charges). There's some talk of using the '88-'91 Civic AWD Wagon intermediate shaft and a first-gen Integra's intermediate shaft to build a "hybrid" shaft that will work. Neither of those shafts will work on their own; apparently you have to use the shaft and mount bracket from one, and the seals and dust shields from the other in order to get it to fit perfectly. There's more in-depth info on this over at the ZCResource.com.
As for the limited-slip differential in the ZC transmission: They do exist, and they were available from Honda (the LSD was a factory part, in other words), but they're certainly not common, and definitely not on all ZC transmissions. Most importers will quote you $300 extra for an LSD-equipped ZC tranny, IF they have any in stock. I order in bulk (6-12 ZC transmissions at a time), and the last shipment I got had one of the LSD-equipped transmissions in it. They didn't even upcharge me for it - because they didn't notice it!
Mike
Modified by Kwicko at 3:55 PM 10/21/2005
Old Oct 21, 2005 | 12:55 PM
Bense's Avatar
Default Re: (Kwicko)
PM'd
alx_90ef
13
Sep 29, 2009 04:24 AM
Modern91Hatch
Apr 25, 2008 08:38 AM
user 98292739
22
Oct 13, 2004 10:09 PM
Kato7997
Mar 3, 2003 08:23 PM
1990hondaHF
Jul 8, 2002 08:31 PM
