oil pan gasket leak ?
Old Oct 17, 2005 | 05:08 PM
Teglessb18's Avatar
Default oil pan gasket leak ?
Is it normal for the oil pan to have what seems like a leak all around it where the gasket is?? Could i be losing oil this way? I am not leaking any oil on the ground but am wondering if this is a problem?
Old Oct 17, 2005 | 05:14 PM
92integraVTECgsr's Avatar
Default Re: oil pan gasket leak ? (Teglessb18)
bump i have the same problem.. I think just a new oil pan gasket and some sealant will do. Im going to replace mine next week with a new seal.
Old Oct 17, 2005 | 05:18 PM
Teglessb18's Avatar
Default Re: oil pan gasket leak ? (92integraVTECgsr)
cool anyone else had this problem before? Hey 92integravtecgsr is your leak in a 92 gsr? If so mine is as well and also have you been losing oil at all?
Old Oct 17, 2005 | 05:21 PM
verbol assassin's Avatar
my car never had an oil leak, until i started to let the mechanic change my oil.
no i have a cam seal leak, oil pan gasket leak. my car is just messy.
my driveway use to be clean.
no i have oil drips all over my driveway, which i have to clean out every weekend with simple green, cuz it makes my rich neigbors mad.
u are ruining the value of our home. stop maintaining your car in the drive way, go to a mechanic. etc. etc........
Old Oct 17, 2005 | 06:04 PM
Teglessb18's Avatar
Default Re: oil pan gasket leak ? (verbol assassin)
ok did you have a oil pan gasket leak or what?
Old Oct 17, 2005 | 06:11 PM
Teglessb18's Avatar
Does anyone know if this could be causing me to be loseing oil?
Old Oct 17, 2005 | 06:13 PM
yes, and ur car could also be burning oil, how much mileage?
currenlty, my cam seal is leaking, which is causing me to loose a bunca oil. almost 1 qt. every 3000 miles.
Old Oct 17, 2005 | 06:17 PM
Teglessb18's Avatar
140,xxx miles I dont think it is burning oil.
Old Oct 17, 2005 | 07:01 PM
ok.. i have 238,800 miles on my stock 92 gsr. i am not loosing any oil due to this leak. it just builds up around there, but nothing is ever on the ground. i ONLY loose oil when use VTEC. other than that.. i dont really burn oil.. i changed my VTEC solenoid gasket and my cam seals are fine..
so other than VTEC burning oil, my car is good except for the oil pan.
Teglessb18's Avatar
here are some pics.
sorry about the large size I do not have a photo editor.
Old Oct 17, 2005 | 07:06 PM
that really isnt that bad.. i got a lot more oil built up around my seal and im missing every other nut and bolt. in some spots, im missing 2 or 3 bolts in a row.
Old Oct 17, 2005 | 07:21 PM
Teglessb18's Avatar
damn do you think this could be a cause of lost oil?
Old Oct 17, 2005 | 07:26 PM
tegrevboy's Avatar
maybe use the macro setting on your camera ...J/k that really isnt' that bad mine is also leaking and missing a few nuts and bolts...
Old Oct 17, 2005 | 07:29 PM
Default Re: oil pan gasket leak ? (tegrevboy)
nah.. you must be leaking oil from somewhere else.
Old Oct 17, 2005 | 09:42 PM
bogey883's Avatar
I just got mine repaired..oil leaking from valve cover and oil pan gasket..and got a bunch of other seals done.
so much cheaper to buy the parts seperately.
I got them at http://www.rockauto.com
Old Oct 18, 2005 | 09:53 PM
Teglessb18's Avatar
Default Re: (bogey883)
awesome thanks man. I put a quart of oil in today and seems to be running a lot better. I am going to monitor it very closely. I think the issue of readings on the dipstick was due to insufficiant amount of oil put in when i had my oil changed. I have learned never to trust anyone with my car.
Old Oct 19, 2005 | 05:22 PM
ProjectLSVTEG's Avatar
Default Re: (Teglessb18)
<---- replacing my oil pan gasket saturday (my day off) at my work, god its great to have access to parts at cost, lifts, alignment machines, and every tool i could ever need to use!
Anyways, if you guys want a how-to (i dont know if there already is one), I could take some pics... it should only take about an hour (prob less with a lift and air tools).
Old Oct 19, 2005 | 05:57 PM
Teglessb18's Avatar
Default Re: (ProjectLSVTEG)
yes i work at honda as well however I am just a porter. Anyways If you wan tto take pics you could but it doesnt look like a hard job.
Old Oct 20, 2005 | 05:04 PM
its extremely simple
Old Oct 20, 2005 | 08:04 PM
scartail's Avatar
Check your oil filter... I swap my oil pan gasket three times back to back thinking it was the oil pan... Then I realize it was my oil filter leaking on to the oil pan flange area... and eventually spread itself around... Sux... nowadays, I still see some oil residue collecting under my oil filter... don't know why.. I always lub up the filter gasket before i install it and wip the gasket surface.
Old Oct 21, 2005 | 06:04 AM
HONDA RR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if this could be causing me to be loseing oil?</TD></TR></TABLE>
It could possible be the primary reason that your loosing oil unless you have other factors that contribute to it.
Old Oct 21, 2005 | 06:09 AM
LL2009's Avatar
Default Re: oil pan gasket leak ? (HONDA RR)
try cleaning or degreasen the bottom of your car so you can see where the leak if coming from. ill be easier then to buying all these gaskets guessing where the leak is coming from ..
Old Oct 21, 2005 | 07:49 AM
Teglessb18's Avatar
Default Re: oil pan gasket leak ? (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">try cleaning or degreasen the bottom of your car so you can see where the leak if coming from. ill be easier then to buying all these gaskets guessing where the leak is coming from .. </TD></TR></TABLE>
Thats what i did and I am monitoring it too see whats going on. Great Advice.
Old Oct 21, 2005 | 12:44 PM
ecks_fourttwo's Avatar
i had almost the same problem...everytime i hit vtec, looking in my rear view all i would see was white smoke, not to mention the smell of burning oil in the car... i found the leak and it was my oil pan gasket... it was an easy fix and it helped out. i had no more smoke and now im saving on the expense of buying oil.
Old Oct 21, 2005 | 12:53 PM
TurboGS-R's Avatar
Default Re: oil pan gasket leak ? (ecks_fourttwo)
I've had the same problem, but much worse for a while now. I have had to replace the oil pan gasket once already because of boost pressures, which a catch can will help. Perhaps a catch can could help you too, but I just think your gasket is just wearing away slowly for whatever reason and there's no need to replace it yet unless it's really a problem to you.
