p07(vx) ECU chippable with uberdata?
Old Oct 17, 2005 | 04:39 PM
dturbo's Avatar
Default p07(vx) ECU chippable with uberdata?
I have not yet seen uberdata chipped with a p07 or VX ecu. Is it possible and is it the same as doing a p28 if possible?
Old Oct 17, 2005 | 04:46 PM
JDMlyfestyle's Avatar
sorry to say bro.. but why dont you go check out PGMFI.org and see.. cause that is a straight ECU tech forum. and would help you more than HT will.
Old Oct 17, 2005 | 05:27 PM
specv5150's Avatar
I was talking to a guy on here that does ecu chipping and service and I beleive some of the VX ECU's are chippable but he said that you couldnt run the stock VX program. I inquired because I wanted the benefits of chipped ECU and OBD1 AND to retain the stock VTEC-E program. Said it couldnt be done and keep the stock VTEC-E program
Old Oct 17, 2005 | 07:45 PM
93turbo16's Avatar
Default Re: (specv5150)
The only ecus that are chippable are the VX california modles. The other ones have a few more processors than a normal ecu and are a pain in the ***. But you can do it if you have a cali model, it uses the P28/P06 board.
Old Oct 17, 2005 | 08:00 PM
AbitAvenger's Avatar
uberdata.pgmfi.org
edo3276
May 25, 2004 11:29 AM
Nader_D
Sep 30, 2003 12:38 AM
gsrvx
Jan 31, 2003 07:26 PM
ahcjar103
Mar 13, 2002 04:27 AM
