List of Suspension Bushing to Replace
Anyone out there have a list of suspension bushings I should replace on my 15 Year old 1990 Honda CRX si with a b16a swap. I heard the energy suspension bushings are not good for street use, as you will feel every single bump. I want a nice comfortable ride, and dont use my car on the track.
I'm thinking of going Genuine Honda Parts. Any idea what the labour cost would be?
Also last question, would it be better to just purchase new control arms with the bushings?
thanks ur all ur help.
front upper control arms - new bushings and balljoints $90 each
bushings - $12 x 2
aftermarket balljoint - $70? (oem not available, ive only HEARD theyre available somewhere)
buy the whole arm.
front lower control arm - new bushings. $129
inner bushing - $18
shock bushing - $14
buy the bushings separately.
front lower balljoint - $45
tie rod end - $46
tie rod inner - $43
rack end bushing - $8 (THIS IS A MUST!)
rear toe arm - $31
bushing - $12 x 2
cheaper to buy bushings, but worth the small difference to buy the arm complete, no need to press.
rear upper arm - $43
inner bushing - $23
outer bushing - $14
same thing as above, better to get the whole arm.
rear lower arm - $69 (they raised the price $5 recently?)
bushing - $14 x 2
shock bushing - $14
same as above. but i think they lowered the price of the bushing and raised the cost of the arm a bit... before it was the SAME to buy the bushings separately vs arm complete.
trailing arm bushing - $45
not feasible to buy the whole trailing arm anyway.
bushings - $12 x 2
buy the whole arm.
inner bushing - $18
shock bushing - $14
tie rod end - $46
tie rod inner - $43
rear toe arm - $31
bushing - $12 x 2
inner bushing - $23
outer bushing - $14
bushing - $14 x 2
shock bushing - $14
Rob.
11
Jul 8, 2012 07:13 PM
Rob.
Suspension & Brakes
Jul 8, 2012 10:29 AM
