what causes bad knock sensor?
Old Oct 17, 2005 | 02:48 PM
Layziejoe775's Avatar
Default what causes bad knock sensor?
i have a code 23 and i believe that is knock...what caused this to become bad so in the future i know what to do....in addition, what is the best and afforable way to go around this...new knock $125 or used $$$??
Old Oct 17, 2005 | 02:56 PM
prelittlelude's Avatar
Default Re: what causes bad knock sensor? (Layziejoe775)
after a while the small electrode in the sealed knock sensor rusts and corrodes, either that a code 23 is caused by and unpluged knock or bad wire..
the prelude knocks root out. and go bad
your lucky you even got a code 23 , sometimes bad knocks go for a while without ever throwing a code and tell the ecu the motor is knocking when its not and it killl performacne and gas mileage
Old Oct 17, 2005 | 04:12 PM
Under_Pressure's Avatar
Default Re: what causes bad knock sensor? (prelittlelude)
I got a new KS for sale. pm me for info
Old Oct 19, 2005 | 11:10 AM
thanks...but i should include the whole family of problems: 21, 23, and 43!....i don't know where to start....i thought installing a msd blaster 2 coil will solve my rich problem.....guess i was wrong..although i didn't hook up a resister yet....deng...
Old Oct 19, 2005 | 11:12 AM
mgags7's Avatar
why would you install an aftermarket part to try to fix problems with your cars oem electrical system...
that just throws another variable into the equation...
sir2sol
Apr 1, 2005 04:55 PM
kholmes
Mar 10, 2005 04:47 PM
Trygge
May 14, 2004 09:16 PM
Fardoche
Jul 31, 2003 10:29 PM
hondaspeder
Jun 19, 2003 09:21 PM
