help? which crank, which flywheel?
Old Oct 17, 2005 | 02:03 PM
(puma)'s Avatar
Default help? which crank, which flywheel?
i'm finishing up my b16 build,but theres a good chance i may not be using a b16 tranny. if i'm going to be using an ls tranny does that mean that i will have to use the ls flywheel with my b16 crank? or can i use my b16 flywheel? i have b16 flwheel that came with the block.
Old Oct 17, 2005 | 03:32 PM
00ekhatch's Avatar
Default Re: help? which crank, which flywheel? (Jus_B)
as far as i know, the b-series tranny is entercahngable betweem the b series engines. the only differance in a b16 crankshaft and b18 is the stroke so if you put an ls crank into a b16 you are prob going to run into clearance problems.but the tranny (as long as it is a b-tranny) will bolt up to your b16.
Old Oct 17, 2005 | 03:47 PM
(puma)'s Avatar
Default Re: help? which crank, which flywheel? (00ekhatch)
no i know that man,i'm just trying to find out if i should use an ls flywheel or if i can use the b16 flywheel.
Old Oct 17, 2005 | 03:55 PM
NJIN BUILDR's Avatar
You can use either flywheel with either tranny
Glenn
Old Oct 17, 2005 | 04:36 PM
(puma)'s Avatar
Default Re: help? which crank, which flywheel? (NJIN BUILDR)
thanks
watsvtecEK
Jan 25, 2006 07:24 PM
94lsboost
Oct 30, 2003 01:37 AM
lazy bum shaughn
Apr 6, 2003 03:38 AM
