Can anyone decipher auto zone engine codes? Car throwing 6 codes
Old Oct 17, 2005 | 12:36 PM
verbol assassin's Avatar
Default Can anyone decipher auto zone engine codes? Car throwing 6 codes
Alright, I've been having some transmisson problem so I went to autozone and found out that my engine is throwing about 7 different codes.
1: Code 1 is obvious: insufficient purge flow.
The rest of the code seems alien to me. WTF are they?
2: P0700 - TCS Malfuncion
3: P1753 - Maf. Control Trans
4: P1758 -
5: P1706
6: P0753 - Shift Solenoid B Circuit
7: P0758
The last 6 all pertain to my transmission. I did an auto - manual swap and everything was running good for 3 weeks, after i took it out and kinda over revved on accident (on cell phone and lost, looking for the god damn small street on a busy highway). and all of a sudden, this crap all happend to me. expletive.
Am I suppose to only look at the last 2 digits?
God damn, 7 codes, gonna cost me an arm and a leg. expletive.
Old Oct 17, 2005 | 12:39 PM
LoseRPunKx182's Avatar
Default Re: Can anyone decipher auto zone engine codes? Car throwing 6 codes (verbol assassin)
they should have this little book that tells them steps in what to look for from the codes...i could bring one home from work but that wont be till tmorrow..good thing is most of the time..fixing 1 or 2 of the codes will fix the rest
Old Oct 17, 2005 | 01:36 PM
Echo7847's Avatar
Default Re: Can anyone decipher auto zone engine codes? Car throwing 6 codes (LoseRPunKx182)
p0700 - auto trans control system dtc
p1753 - problem in torque converter clutch solenoid valve a circuit
p1758 - problem in torque converter clutch solenoid valve b circuit
p1706 - open in trans range switch circuit (no gear position inputs)
p0753 - problem in shift solenoid valve a circuit
p0758- problem in shift solenoid valve b circuit
Old Oct 17, 2005 | 02:55 PM
Default Re: Can anyone decipher auto zone engine codes? Car throwing 6 codes (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">p0700 - auto trans control system dtc
p0758- problem in shift solenoid valve b circuit</TD></TR></TABLE>
"auto trans control system dtc?"
whats that? i have a manual tranny, and supposedly a manual ECU.
how do u tell the difference between an auto ecu and manual?
i'll post some pics if i can.
Modified by verbol assassin at 4:17 PM 10/17/2005
Old Oct 17, 2005 | 03:20 PM
ProjectLSVTEG's Avatar
Sounds to me like the ECU isnt a manual.... If it were, there is no way it would throw any of the Trans Codes. My bro got shafted on an auto ecu with his B16 swap, and it runs fine, just throws the tranny codes, untill he gets his new one.
Anyways, I'd ignore the Auto Trans codes, and worry about fixing the other one first, then replace the ECU, and that annoying CEL light will go off.
Old Oct 17, 2005 | 03:31 PM
Default Re: Can anyone decipher auto zone engine codes? Car throwing 6 codes (ProjectLSVTEG)
well the problem is, when i drive to about 3k. my car crusies by itself, i dont need to step on the pedal.
when i shift to neutral, while at 3k, the engines revs to 4k by itself, and i have to tap on the pedal to let the rev go back down to 700.
lets says on driving on the freeway at 60mph, reving at about 3k or so. i can let go of the pedal and cruise all day w/o stepping on the gas.
i dont think its the ecu, cuz i've been driving for 3 weeks without a problem. this just happend out of no where.
Old Oct 17, 2005 | 04:48 PM
Echo7847's Avatar
Tried to clear the codes and see if they come back? open up the ecu and check to make sure its manny
Old Oct 17, 2005 | 04:57 PM
i reseted my ecu, and once i step on the gas, the lights goes back on.
how do you tell if the ecu is a manual?
my car has too many issues at the moment, i hope i can fix some and let the mechanic handle the rest.
Old Oct 17, 2005 | 05:26 PM
This is an automatic ecu right? A for automatic?
Old Oct 17, 2005 | 07:58 PM
tegrevboy's Avatar
well is your transmission control unit still hooked up? it may still be plugged in. And your cruise control unit may still be hooked up...YOu might want to check this i went ahead and took my cruise control unit from my manual parts car and put it in the auto cruise controls place...
notice one says p-75 AT and the other says p-72 MT
take a look at those and also make sure that your auto transmission control unit isn't still hooked up...
here is one pic of a obd-1 p72 manual ecu and a obd-1 auto p-75 ecu
Old Oct 17, 2005 | 08:22 PM
Default Re: Can anyone decipher auto zone engine codes? Car throwing 6 codes (tegrevboy)
a thanks for ur post man, that was really helpful. hopefully i'll get to it. im still at work till midnight
renzis00
25
Sep 24, 2012 09:47 PM
jrap1243
Jan 23, 2012 11:56 AM
99CivicSiBrian
Apr 10, 2006 01:47 PM
