2000 rpm idle
Old Oct 17, 2005 | 12:32 PM
Crimson_Tide's Avatar
Default 2000 rpm idle
as the title says im having idle issues... finally got the car to run perfect and then i went to swap throttle bodies... found out that the guy on ebay sent the wrong one so i made a gasket out of a rubber gasket material and put my old one back on... while i had the throttle body off i adjusted the FITV... i took the back plating off and screwed the inside part all the way towards what would be the front of the car... i also flushed my cooling system and put new fluid back in... now my car idles at 2k until it warms up and then it bounces from 1-2k... what do i need to do? thanks for all the help guys
-Josh
Old Oct 17, 2005 | 12:39 PM
Mr_Si-R's Avatar
i know on my old nissan i had to adjust the a scew on the throttle body to get the idle right
Old Oct 17, 2005 | 12:58 PM
Default Re: (Mr_Si-R)
yeah my buddy told me that there was one... it was located towards the top of the tb but it was facing the drivers side... would that be it?
Old Oct 17, 2005 | 01:01 PM
Mr_Si-R's Avatar
im positive for a nissan, but honda, that one im not too sure on, but hey, try it and if it dont work, then just move it back
Old Oct 17, 2005 | 01:13 PM
MadModder's Avatar
Depending on your engine the iacv (idle air control vale) may be in a different place but on my d16y8 it's on on the passenger side of the throttlle body near the intake tube. The screw was in the same location on my d16a6 and d16z6 so I am guessing it's the same for all D series motors.
Old Oct 17, 2005 | 01:23 PM
Default Re: (MadModder)
i have a z6... the screw is on the tb and the iacv is near the tb on the back of the intake manifold... but not on the trottle body... well i have to be someplace at 5:45 so im going to go try that screw and see if it works
-Josh
Old Oct 17, 2005 | 05:18 PM
Default Re: (Crimson_Tide)
well i tried the screw and it didnt change anything... i also noticed that the throttle body wasnt pulling in a lot of air so i completly blocked it off with my hand and the motor still ran... so i thought to myself "gee i must have a vaccume(sic) leak" i checked all my hoses and theyre all fine... i noticed a leaking sound coming from the bottom of my tb... could i have not made the gasket right and air could be leaking in through where it meets the intake manifold? i put the gasket up to it and it looked a little iffy on some parts but i thought it was pretty good overall... what do you guys think?
-Josh
Old Oct 17, 2005 | 06:10 PM
stdefhatch's Avatar
http://www.ef-honda.com/ben/
its in the tech part under the engine category "bad idle trouble shooting"
that should help you out
Old Oct 17, 2005 | 07:37 PM
Crx Jimmy's Avatar
gasket is probably not sealing good,spray some carb cleaner near the tb gasket and see if the sound of the motor changes, the rpm will change if its leaking
Pashpacino
Engine Management and Tuning
Mar 13, 2018 06:23 PM
erichackett
10
Jul 27, 2010 06:43 PM
95dc2teg
Sep 11, 2007 05:49 PM
michael_antoi
Feb 22, 2006 03:36 AM
2fknlo
Sep 13, 2004 01:15 PM
