Civic not starting right now! argh!
i have to be at work in an hour and need help quick, so my car has done this once before but i can't get it fixed until this friday on payday. i have a d16z6 my problem is that after running it today i turned it off at a friends house for about 20 minutes when i got back in my car it started fine but when i went to hit the gas it sputters and boggs like its going too die. then once i get a little harder on the gas it comes back with power. now i turned my car off and it won't start back up. has happened before. it turns over but no firing, before i had to wait like 20 minutes before it would kick over by pumping the gas quickly. what is the problem? i am hitting a CEL for O2 sensor and i don't know when the spark plugs/wires were last changed?? sorry i don't have time to search
any quick fix to possibly get it started why is it doing this, i mean after i wait a couple of minutes it will probably fire back up but why is its craping on me like this? IACV???? and where the hell is the IACV so i can try and clean it with carb cleaner?
could it be flooded, i "heard" that if you start your car only for a few secs. your fuel system doesnt go threw the whole cycle and you may have flooded your engine. try starting it with the gas half way down.
Sounds like fuel pump. Specially if you had to wait. When you hit the gas the demand for fuel is greater so the pump raises the pressure, but it can't (for unknown reason) therefore starving the engine from fuel = shutting it down.
combos99
Oct 28, 2013 05:21 AM
Moaltar
Honda Civic (2001 - 2005)
Oct 17, 2013 11:39 AM
thunderfck
Mar 4, 2013 04:19 PM
