Suspension & Brakes Theory, alignment, spring rates....
AXLE is driving me crazy
Old Oct 17, 2005 | 10:00 AM
91-lsvtecsi's Avatar
Default AXLE is driving me crazy
i cant seem to break the axle nut loose i had a 240lbs man step on the breaker bar wat
esle will break the nut loose thanx
Old Oct 17, 2005 | 11:24 AM
robotosan's Avatar
Default Re: AXLE is driving me crazy (88lscrxsi)
yeah this is a bitch.
1. make sure the car is on all 4's and pull the ebrake up
2.and get some one to push on the brakes
3.Get some wd-40 or PB blaster and soak the nut.
4. then use a your breaker bar with a huge *** pipe
5. go to town on that nut.
be prepared to break some tools
and put this in the right forum!
Old Oct 17, 2005 | 10:39 PM
HiProfile's Avatar
Default Re: AXLE is driving me crazy (CRXhf_89)
IMO, a strong impact gun (usually over the 90psi limit) is the way to go. Im my case the first time, getting the axle splines out was the hardest part.
Old Oct 18, 2005 | 07:57 AM
Crazydave's Avatar
Default Re: AXLE is driving me crazy (HiProfile)
Damn.. I must have posted how to do this on at least 5 different threads.
Easiest way is to get an air compressor and a good impact gun.
Pump up the pressure to the max (I usually go to 140+ psi)
Make sure your gun is properly lubed, and that you are using a real impact socket.
Sometimes I use WD-40 or deep-creap or what ever, let is soak
Blast it off!
I've tried other methods, and all I did was break tools, or put skid marks down on the pavement.
davey5300
Nov 12, 2024 02:53 AM
vtechjunkie
31
Sep 27, 2020 06:43 AM
Mr.Meowsome
38
Nov 25, 2006 04:33 PM
JJ's civic
13
Oct 22, 2006 03:42 PM
gsrcivic619
10
Jan 5, 2004 04:07 PM
