NEED HELP!!!!!
Old Oct 17, 2005 | 07:34 AM
Ezrider_03's Avatar
Default NEED HELP!!!!!
I have a 90 Civic Hatch and I’m putting in a 94 B18b1 into it. I need to know can I use the 90 Integra harness w/ this swap or do I need to get a new harness. The motor is stock so I have every thing for the motor I just need to know what harness do I need and will I need to change anything.
Old Oct 17, 2005 | 07:48 AM
VtecSyndrome's Avatar
Default Re: NEED HELP!!!!! (Ezrider_03)
Depending on what model hatch you have you wiring harness will work, do you an Si?? if not then I would reccomend using the '90 Integra harness, either way you have to wire up Vtec and a couple other little things.
Old Oct 17, 2005 | 07:57 AM
HatchBox's Avatar
Skoobie no more...
The 94+ harness wont plug into your interior harness....
you must use the 90 civic harness and use some sort of conversion harness at the ecu.
there is a few people on here who make 0bd0- 0bd1 conversion harnesses
Old Oct 17, 2005 | 08:33 AM
Default Re: NEED HELP!!!!! (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">The 94+ harness wont plug into your interior harness....
there is a few people on here who make 0bd0- 0bd1 conversion harnesses</TD></TR></TABLE>
Well it just depends on whether or not you are going OBD0 or OBD1
Old Oct 17, 2005 | 08:48 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: NEED HELP!!!!! (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">
Well it just depends on whether or not you are going OBD0 or OBD1</TD></TR></TABLE>
good point do you want obd0 or obd1?
Old Oct 18, 2005 | 09:47 AM
Ezrider_03's Avatar
Default Re: NEED HELP!!!!! (Ace$nyper)
I wanted to Stay Obd0...
Old Oct 18, 2005 | 11:54 AM
Ass$nyper's Avatar
then you need mpfi wiring or is your car already mpfi?
Old Oct 18, 2005 | 12:01 PM
88rexA6's Avatar
yea if its not an si just convert to mpfi and its all plug and play
and...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">Depending on what model hatch you have you wiring harness will work, do you an Si?? if not then I would reccomend using the '90 Integra harness, either way you have to wire up Vtec and a couple other little things.</TD></TR></TABLE>
last time i checked an ls was non-vtec
lol just messin...
good luck man
tommyboy042281
21
May 4, 2009 06:20 PM
ikaika3269
10
Feb 26, 2008 06:25 PM
invisible
Nov 19, 2006 09:23 AM
Beau Gotti
Feb 12, 2006 02:11 PM
v-tec maz
Jan 8, 2006 07:01 PM
