Some noise i'm hearing - pissing me off.......
Old Oct 17, 2005 | 05:51 AM
The Weather Man's Avatar
Default Some noise i'm hearing - pissing me off.......
Modified by TheKINGPin at 10:26 PM 2/6/2006
Old Feb 6, 2006 | 02:25 PM
stavros007's Avatar
Default Re: Some noise i'm hearing - pissing me off....... (TheKINGPin)
I know it sounds weird, i had the same , replaced bearings etc to no avail, i checked the trim on and in mybootlid 2 screws loose holding the number plate surround on and also a flappy exhaust shield - seems better now - clos your bootlid hard and hear for any vibrations ?
Old Feb 6, 2006 | 02:39 PM
98TypeSH's Avatar
Default Re: Some noise i'm hearing - pissing me off....... (stavros007)
i think by bootlid he means trunk.
jack the car up and wiggle the tire ( pull towards yourself and push away ) If there is play then the wheel bearing needs to be replaced.
Old Feb 6, 2006 | 04:48 PM
ThE PiMpiN Co's Avatar
Default Re: Some noise i'm hearing - pissing me off....... (98TypeSH)
This is an old thread. He fixed the problem already.
Old Feb 6, 2006 | 05:21 PM
prelittlelude's Avatar
Default Re: Some noise i'm hearing - pissing me off....... (aRaBiAn RiCe)
hmm yeah this is really old, what was the solution to the problem?
Old Feb 6, 2006 | 05:26 PM
Default Re: Some noise i'm hearing - pissing me off....... (prelittlelude)
It ended up being his wheel bearings.
Old Feb 6, 2006 | 06:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aRaBiAn RiCe &raquo;</TD></TR><TR><TD CLASS="quote">It ended up being his wheel bearings.</TD></TR></TABLE>
Yep. Wheel bearing - since it was the rear, had to replace the entire hub. Everythings good now.
tcsubaru
Jan 11, 2012 09:49 AM
frostcivic
May 11, 2006 02:23 AM
JDM97R
Suspension & Brakes
12
Feb 17, 2006 02:02 AM
Ichigo
Jan 29, 2006 07:52 PM
ronald55555
12
Mar 9, 2005 07:58 PM
