D16z6 CRX.. converting to OBD1..remove resistor box?
I am planning to convert my crx to OBD1 because of emissions. i was just wondering if i should remove the resistor box? Or what should i do?
If you run OBD1 injectors, you remove the box and directly connect the 12v+ wire to the 4 injector wires at the IRB plug. If you run OBD0 Injectors you continue to use the resistor box.
You do not need to upgrade to OBD1 Injectors when converting to a OBD1 ECU/Distributor.
See http://www.rywire.com for your conversion.
Randysi
Apr 4, 2012 10:17 AM
nevin
Aug 16, 2005 03:21 PM
