European Civic Type-R(K20 engine - vtec - 200hp) - WHICH SUPERCHARGER?
Old Oct 17, 2005 | 12:39 AM
dark-b16a1's Avatar
Default European Civic Type-R(K20 engine - vtec - 200hp) - WHICH SUPERCHARGER?
Hi guys, remember my last post where I was trying to find out what's the best tune for Civic Type-R, you recommended me a small supercharger.
I decided to go with Jackson Racing "race" type SC, but I have a small problem. Since the Civic Type-R(CTR) is not distributed in US(AFAIK) with the VTEC engine, there is no direct support of ECU for this type from Jackson Racing. I thought I'll go with setup for Acura RSX, as the engine should be the same, but ECU is different.
Jackson Racing has a distributor in UK, they do the european version, but they asked for £2700 , that's almost 50% more than US prices
Do you think I could use the K-pro unit with European version of Civic Type-R ?
Old Oct 17, 2005 | 02:22 AM
giff74's Avatar
Default Re: European Civic Type-R(K20 engine - vtec - 200hp) - WHICH SUPERCHARGER? (dark-b16a1)
I think the easiest thing would be to get domestic supercharger parts and k-pro. Then go to competent tuner and have them tune your k-pro.
That set up sounds like a monster! Good luck!
Old Oct 17, 2005 | 04:28 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dark-b16a1 &raquo;</TD></TR><TR><TD CLASS="quote">Do you think I could use the K-pro unit with European version of Civic Type-R ?</TD></TR></TABLE>
Hondata are very customer service oriented.
If I were you I would correspond with (or ring up) both Jackson Racing and Hondata and ask them if the K Pro will work with what you have in mind.
I am sure that Hondata have enough experience with the many, many CTR swaps in the USDM that they will be able to advise you.
Old Oct 17, 2005 | 04:29 AM
dark-b16a1's Avatar
Default Re: European Civic Type-R(K20 engine - vtec - 200hp) - WHICH SUPERCHARGER? (giff74)
there is nothing like a "competent tuner for K-pro" in here, central Europe( and not because it's a dump just because people tune european cars here more).
I have to do the ECU tuning and my one of my buds is going to do the mechanical installation.
I definitely need the Jackson Racing SC, that's what the guy who owns the CTR wanted to have this installed.
We are basically doing this as amateurs, and fans of Honda( I have CRX&B16A1 and Civic D16A6 with IHI turbo) so I do have some experiences with ECU tuning.
What I needed to know is what's the best solution in implanting Jackson Racing SC on a European civic type-r....
Old Oct 17, 2005 | 07:20 AM
sk8flex's Avatar
There is a German CTR running JRSC together with K-Pro and from what I´ve heard so far the car is running fine.
Where are you located exactly?
Old Oct 17, 2005 | 10:39 PM
dark-b16a1's Avatar
Default Re: European Civic Type-R(K20 engine - vtec - 200hp) - WHICH SUPERCHARGER? (sk8flex)
German CTR? Do u have a contact for this guy? That would really help... I'm from Czech Republic....
Old Oct 18, 2005 | 07:42 AM
sk8flex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dark-b16a1 &raquo;</TD></TR><TR><TD CLASS="quote">German CTR? Do u have a contact for this guy? That would really help... I'm from Czech Republic.... </TD></TR></TABLE>
I will check if can find out his email addy for you.
But you could check with these guys in Switzerland first, they are very experienced with JRSC setups on the European EP3.
http://www.rikli-sportgarage.ch
9tailsfox
May 23, 2018 08:38 AM
LUV4JDM
Jan 2, 2016 09:35 AM
Skoust
Oct 31, 2011 02:09 PM
djnikko
Sep 9, 2003 07:08 AM
BlackJDMep
Jun 12, 2003 07:53 PM
