Suspension & Brakes Theory, alignment, spring rates....
Comparison Skunk2/Koni yellow VS Ground control/stock shocks
Old Oct 16, 2005 | 10:43 PM
VIS250P's Avatar
Default Comparison Skunk2/Koni yellow VS Ground control/stock shocks
CAn you explain to me the difference between two coilovers. On my friend 00 Civic Hb with Ground Control and stock shocks which is not bouncy. On my Type R with skunk2 coilover, Ground control Top Hat and Koni yellow is bouncy like a basketball dribble.. Should I get Ground Control coilover instead of Skunk2 coilover. LEt me know
Old Oct 16, 2005 | 11:11 PM
KOALA YUMMIES's Avatar
Default Re: Comparison Skunk2/Koni yellow VS Ground control/stock shocks (py)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">On my Type R with skunk2 coilover, Ground control Top Hat and Koni yellow is bouncy like a basketball dribble.. </TD></TR></TABLE>
Thats probably because you've set the ride height so low you no longer have shock travel, just bumpstop travel
Old Oct 16, 2005 | 11:17 PM
VIS250P's Avatar
Default Re: Comparison Skunk2/Koni yellow VS Ground control/stock shocks (KOALA YUMMIES)
Hmm True but what about the Ground Control coilover.. Does it matter of the spring rate make the difference?
Old Oct 17, 2005 | 11:43 AM
stock99's Avatar
Most likely your GC/stock shocks will blow eventually. I rode my car w/GC/stock shocks for about a year, now the shocks are totally blown. I'm lookin to run the GC's with Koni Yellow shocks now.
Old Oct 18, 2005 | 11:08 AM
areyouasian's Avatar
Default Re: Comparison Skunk2/Koni yellow VS Ground control/stock shocks (stock99)
use ground control/koni yellows. they will give you a great ride. i had GCs w/stock shocks and the shocks blew out eventually. so you might as well get them. i've experience skunk2 along with a couple other types of coilover suspensions before and i have to say that GC's were the best out of all of them.
Old Oct 21, 2005 | 01:50 PM
stock99's Avatar
Default Re: Comparison Skunk2/Koni yellow VS Ground control/stock shocks (areyouasian)
Do you know if sleeves are needed w/GC's and Koni yellows? Currently I have GC's with stock shocks...
Old Oct 21, 2005 | 10:31 PM
VIS250P's Avatar
YEs the GC sleeve for Koni yellow and stock shocks are different. U can look inside the Sleeve and see the O ring hanging which is mean that is for Koni yellow.. IF there is no O ring inside the sleeve which is mean that can fit on stock shocks or other brands..
Old Nov 1, 2005 | 01:04 AM
dawalude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">Hmm True but what about the Ground Control coilover.. Does it matter of the spring rate make the difference? </TD></TR></TABLE>
yeah it does matter, the skunk2 spring rates are more than the ground control, which affects how stiff your suspension is. so it gives it that "bouncy" feel compared to if you had ground control. if you are concerned about ride quality, get the ground controls w/ koni. you probably wont notice any big difference in handling since you are already that low
Modified by dawalude at 2:34 AM 11/1/2005
Old Nov 1, 2005 | 09:46 AM
verycleanhatch's Avatar
Get ground control and you can choose specific rates(you could have it stiff or soft).Not related too your question but would love more pics of that R.
Old Nov 1, 2005 | 10:33 AM
radio1global's Avatar
Just get the stiffer rates from Eibach and custom spring length.
Inline Racing
Houston,Tx
mish__
Suspension & Brakes
Aug 27, 2011 03:41 AM
chrisff521
Mar 23, 2010 12:34 PM
07rebel
Honda Civic (2001 - 2005)
May 2, 2008 01:43 PM
longdongdan96
Dec 31, 2003 02:17 AM
