Intake Funnel in the front of the car....
Old Oct 16, 2005 | 09:10 PM
RICE POLICE SIP's Avatar
Default Intake Funnel in the front of the car....
I searched and couldn't find anything.... How do people usually mount the Funnel on the front of the car.... Like this one....
on kenny trans car....
Old Oct 16, 2005 | 09:20 PM
flip1199's Avatar
Default Re: Intake Funnel in the front of the car.... (Split Image Prez)
fyi it's called a "velocity stack".
Old Oct 16, 2005 | 09:21 PM
Default Re: Intake Funnel in the front of the car.... (flip1199)
You know I was thinking that too but I wasn't 100% sure and I've been up for almost 36 hours... LOL ... thanks by the way...
Old Oct 16, 2005 | 09:45 PM
Rage Cayman's Avatar
Autuzone sells the velocity stacks vor $19 bucks..
Old Oct 16, 2005 | 11:57 PM
msmotorsports's Avatar
You can use rivets to mount to the front end.
Old Oct 17, 2005 | 04:43 AM
DaveF's Avatar
Default Re: Intake Funnel in the front of the car.... (msmotorsports)
we fiberglassed ours in. this is a turbonetics velocity stack. i belive its 25 bucks for the velocity stack, a coupler and 2 tbolt clamps.(4inch)
Old Oct 17, 2005 | 04:47 AM
JSpin's Avatar
Default Re: Intake Funnel in the front of the car.... (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">we fiberglassed ours in. this is a turbonetics velocity stack. i belive its 25 bucks for the velocity stack, a coupler and 2 tbolt clamps.(4inch)
how much of a pain is it to secure it once you put the frond end back on?
Old Oct 17, 2005 | 04:54 AM
DaveF's Avatar
Default Re: Intake Funnel in the front of the car.... (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">
how much of a pain is it to secure it once you put the frond end back on?</TD></TR></TABLE>
lol. we still havent built the tube to go from the velocity stack to the turbo.
Old Oct 17, 2005 | 09:45 AM
You really don't need to secure the turbo to the velocity stack. If you are making a manifold, you can position the turbo to sit right behind the velocity stack. If your not making a manifold it will be difficult to always have to reach under the front end to secure clamps and hoses.
Old Oct 17, 2005 | 10:20 AM
Wickdkid77's Avatar
Put the stack on like dturbocivic's or Kenny Tran's but don't attach it to the turbo, in some cases you can ruin the dynamics of how the turbo draws in air if you connect something to it. Fabricate the outlet of the velocity stack to end up about 1.5-2 inches away from the inlet of the turbo.
Old Oct 17, 2005 | 10:34 AM
4piston's Avatar
Default Re: Intake Funnel in the front of the car.... (Wickdkid77)
You don't want to have to line up a pipe with the stack. In my opinion that is a serious pain in the ***.
Old Oct 17, 2005 | 08:55 PM
Default Re: Intake Funnel in the front of the car.... (4piston)
Thanks for all of your responses... The way i'm doing mine is..... I'm using a pipe/coupler from the turbo inlet then connecting the pipe to the velocity stack... Does that sound like a bad idea?
Old Oct 17, 2005 | 10:14 PM
LeGeND4LiFe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wickdkid77 &raquo;</TD></TR><TR><TD CLASS="quote">Put the stack on like dturbocivic's or Kenny Tran's but don't attach it to the turbo, in some cases you can ruin the dynamics of how the turbo draws in air if you connect something to it. Fabricate the outlet of the velocity stack to end up about 1.5-2 inches away from the inlet of the turbo. </TD></TR></TABLE>
Is this even when you put an intake on the turbo?
Old Oct 18, 2005 | 05:09 AM
JSpin's Avatar
thanks for the responses mark and wicked...
Old Oct 18, 2005 | 05:55 AM
fabnewb's Avatar
Default Re: Intake Funnel in the front of the car.... (LeGeND4LiFe)
i think the reason why you wouldn't want to restrict a "ram" funnel by putting a coupler to it is because y9ou may cavatate the turbo meaning you may push more air in there than the turbo can compress causing it to slow down and back spin. So all the excess air needs somewhere to go.
Old Oct 18, 2005 | 09:21 AM
Default Re: Intake Funnel in the front of the car.... (fabnewb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabnewb &raquo;</TD></TR><TR><TD CLASS="quote">i think the reason why you wouldn't want to restrict a "ram" funnel by putting a coupler to it is because y9ou may cavatate the turbo meaning you may push more air in there than the turbo can compress causing it to slow down and back spin. So all the excess air needs somewhere to go. </TD></TR></TABLE>
Do you think that will actually cause TOO much air to fed to the turbo? I'm not a turbo GURU (by any means) or anything but I don't think driving at a 100+ MPH will cause the turbo to slow down.... At the RPM the engine will be turning at "should" be WAY faster then the air flow coming at ya'.... Not being a wise @ss or anything, just saying what I think... Correct me if i'm wrong though...
Old Oct 23, 2005 | 08:33 AM
JSpin's Avatar
back from the dead.........
does anyone have any real world results using a stack versus no stack? i'm thinking it would act quite differently on the the track at 130mph compared to the dyno.
gosu08
Oct 10, 2006 08:54 PM
ProjectCD5
Sep 9, 2006 03:50 PM
the.hamburglar
12
May 17, 2004 06:10 AM
14eight
28
May 8, 2003 10:01 PM
