4 gen cluster conversion question
Hello, i would like to know if the 94-96 cluster with the invertor box is plug in and play for the 92-93? cuz the 92-93 doesn't have a invertor box. Is there a write up cuz that will help a lot. thank you
It's only a plug and play with a 94-96 dash wiring harness. Have a look around on junkyards or anyone that is parting out a 94-96 prelude. You can splice the wires as well, but I don't know how. I just bought a wiring harness and when I signal, both of my signals flash in the cabin but outside it works just fine. Oh yeah, and my interior lights died, I'm too lazy to figure out why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herovueboi »</TD></TR><TR><TD CLASS="quote">It's only a plug and play with a 94-96 dash wiring harness. Have a look around on junkyards or anyone that is parting out a 94-96 prelude. You can splice the wires as well, but I don't know how. I just bought a wiring harness and when I signal, both of my signals flash in the cabin but outside it works just fine. Oh yeah, and my interior lights died, I'm too lazy to figure out why.</TD></TR></TABLE>
its cuz theres an extra black wire on the passenger side of the dash wiring harness that needs to be grounded, if you ground it, then they should work fine
so, it's a plug in and play with invertor box of course and then just ground the black wiring harness onm the passenger side?
Yes, it's as simple as that, well it was for me. I'll have a look at that ground, I thought about it then I said screw it...I got time today so I'll get it done right.
By the way, is this the one that I'm suppose to ground? If so, how the hell do I ground it...cut if off and ground or is there a point I can ground this to?
Modified by herovueboi at 4:59 PM 10/17/2005
Edit #2
Yeah, searched and my question was answered. The black part goes to ground, which I used a ground right next to the dimmer relay.
Modified by herovueboi at 5:34 PM 10/17/2005
Edit #2
hondagurl00
Nov 6, 2011 01:01 PM
suspendedHatch
Apr 26, 2006 07:16 AM
Black 2K
May 17, 2003 10:34 AM
