D16 from Hmotorsonline
Old Oct 16, 2005 | 07:15 PM
xfletcherxx's Avatar
Default D16 from Hmotorsonline
I ordered my D16 from HMotors and was wondering how I could identify what kind of D16 it is? The sticker on the timing belt case is gone, so I really have no idea how else to identify it. It's from a 95 4 Door Sedan Automatic, and I pulled the AT plate off and put it into my civic.
Old Oct 16, 2005 | 07:24 PM
.Ry's Avatar
.Ry
Default Re: D16 from Hmotorsonline (xfletcherxx)
Take a look on the left front side of the motor. Just below the head should be a slanted part of the block that says like "D16Y8" or D16Y7", I can post a pic if you want.
Old Oct 16, 2005 | 07:30 PM
Default Re: D16 from Hmotorsonline (turner7205)
If you like you can post a picture, I can't check till morning since I can't find my damned flashlight.
Old Oct 16, 2005 | 07:41 PM
HiProfile's Avatar
If its from a 95, it'd be a d16z6 (EX). The other civics of that model year were all d15's. If in doubt of it being vtec, open the valve cover, look at the rocker arms on the intake side - you should see a half-size rocker arm stuffed between them, and 5 cam lobes per cylinder.
.Ry's Avatar
.Ry
It will be where the smaller box is. Might have to clean some dirt to actualy see it. It doesnt say on the website what it really is?
Old Oct 16, 2005 | 07:50 PM
No, they don't even have D16's listed on the website. The guy told me it was because they come in and go out so quick, so they usually only stick stuff that is around for a while and is more desired on the website.
Not many people really want a D16 VTEC SOHC.
Old Oct 16, 2005 | 07:54 PM
YeeJ6's Avatar
can i bump this?
Old Oct 16, 2005 | 07:58 PM
.Ry's Avatar
.Ry
Default Re: D16 from Hmotorsonline (spoonspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonspeed &raquo;</TD></TR><TR><TD CLASS="quote">can i bump this?</TD></TR></TABLE> yeah sure why not?
Old Oct 16, 2005 | 08:13 PM
Civic4less's Avatar
How much did you get your D16 for?
Old Oct 17, 2005 | 10:54 AM
Default Re: D16 from Hmotorsonline (Civic4less)
Everything came out to be about about $682.00. Not bad.
Old Oct 17, 2005 | 11:24 AM
GimpyAccord's Avatar
Yikes.. did you look around your area at all first? I got a 1999 D16Y8 for like $150.00 from a local yard w/49k miles on it. Lot of shops that do a lot of swaps are begging for people to take F22's, d16's etc away too.
Old Oct 17, 2005 | 11:25 AM
FalkenSiR's Avatar
Is your engine D16A sohc vtec? Pretty rare engine. 140 hp for a sohc is good
Old Oct 17, 2005 | 11:47 AM
gotboostedvr6's Avatar
Default Re: D16 from Hmotorsonline (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Is your engine D16A sohc vtec? Pretty rare engine. 140 hp for a sohc is good </TD></TR></TABLE>
wtf i want a 140 hp from factory d series what is the complete code d16A. ?
and what vehical did it come in
Old Oct 17, 2005 | 12:14 PM
FalkenSiR's Avatar
Default Re: D16 from Hmotorsonline (gotboostedvr6)
I posted this info in another thread. I'll look for it hold on.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboostedvr6 &raquo;</TD></TR><TR><TD CLASS="quote">
and what vehical did it come in </TD></TR></TABLE>
Old Oct 17, 2005 | 12:15 PM
FalkenSiR's Avatar
here https://honda-tech.com/zerothread?id=1403258 look for my post half way down the first page
Old Oct 17, 2005 | 12:25 PM
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboostedvr6 &raquo;</TD></TR><TR><TD CLASS="quote">wtf i want a 140 hp from factory d series what is the complete code d16A? and what vehical did it come in </TD></TR></TABLE>
No sh*t. I've never heard of this motor either... could be one of the sohc zc motors. As-far as I know none of the ZC's came with anything near 140hp...?
My "ZC" was a D16a6 and it was the DOHC nonvtec (actually out of a 87 LS integra.. but everyone called it the zc).
And for the original poster-- I sold my entire Z6 swap for $200 + an intake. you got robbed. At least you have a warranty.
Old Oct 17, 2005 | 12:29 PM
FalkenSiR's Avatar
Default Re: D16 from Hmotorsonline (mwieczorek43)
It's not a zc but it did exist. I've seen pics of it.
Old Oct 17, 2005 | 12:32 PM
Untill you provide the entire engine-code and/or pics and proof... I'm raising the BS flag.
Old Oct 17, 2005 | 12:35 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">Untill you provide the entire engine-code and/or pics and proof... I'm raising the BS flag.
http://www.angelfire.com/ex2/turbo_vti/ Aparently it also came in VTis
in this guy's case, his car is an EX and the d16a was a straight bolt in.
Old Oct 17, 2005 | 12:39 PM
91civicDXdude's Avatar
well that shows that a d16a actually exists, if you can belive the market on the valve cover. but...... all japanese 1.6L SOHC engines are called "ZC". therefore, the d16a is not a japanese engine, and so i have a hard time believing that 1.) a sohc engine ever had 140hp, and 2.)if it did, it would surely come out in japan and not some other country.
from modifying single cams, i find it hard to belive that they made an additional 15 horsepower without changing the intake manifold, exhaust manifold, or pistons (you ever seen a high compression "d16a" piston? me either)
Old Oct 17, 2005 | 12:41 PM
FalkenSiR's Avatar
Default Re: (91civicDXdude)
I've seen pics of the engine code stamped "D16A" and it was a sohc vtec. Now, the info I came up with could be "of doubtful source" but the engine does exist. It was even here on HT.
Old Oct 17, 2005 | 12:42 PM
I don't doubt the d16 existed (i had one). I doubt that they made anywhere near 140hp.
I quick search yeilded these.... I'm gonna keep looking though..
88-91 HONDA CIVIC EX SOHC 16V EFI (=ZC SOHC) D16A 1.6 4 CALL
88-91 HONDA CIVIC WAGON 4WD SOHC 16V EFI (=ZC SOHC) D16A 1.6 CALL
88-91 HONDA CRX SI SOHC 16V EFI (=ZC SOHC) D16A 1.6 4 CALL
They also came in the 98' Honda Domani... that could be the winner...!
Old Oct 17, 2005 | 12:47 PM
FalkenSiR's Avatar
Default Re: (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">I don't doubt the d16 existed (i had one). I doubt that they made anywhere near 140hp.
You see the EFs are "d16a's" but they are technically ZC's because that's what is stamped on the block.
The domani could be it, tho.
Old Oct 17, 2005 | 02:41 PM
Mine is a ZC SOHC VTEC motor.
Old Oct 18, 2005 | 06:19 AM
Default Re: (xfletcherxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xfletcherxx &raquo;</TD></TR><TR><TD CLASS="quote">Mine is a ZC SOHC VTEC motor. </TD></TR></TABLE>
we dont care... lol we need info on this d16a
CRX MASE
Aug 25, 2015 01:55 PM
pdeminter
Feb 10, 2009 08:09 AM
Ch3mik
33
Oct 30, 2007 08:21 AM
BaD_NeWz
12
Sep 28, 2006 06:10 PM
PotatoePAPA
Dec 30, 2003 06:43 AM
