Gauge Cluster problem...
Old Oct 16, 2005 | 06:42 PM
5lugSlug's Avatar
Default Gauge Cluster problem...
Alright, when i bought my car it had this gay Eurolite Dash kit thing, and it was just complete Rice.. so i took it out today and now i have couple of issues:
1) Speedometer only works if lights are completely on (doesnt work if just parking lights)
2) Tach only works if lights are on (parking or driving lights)
3) I cannot see the white "pointers" at night (if lights are on or off)
4) When i turn the key, only the Oil Light turns red (and your check engine, battery and oil usually do), but if i turn the car on with the lights on.. all 3 lights will turn on
5) I think my speedometer might not be registering the correct speed..
yah its alot how can i fix these problems??
thanks for the help
Modified by EK-tacy98 at 11:52 PM 10/16/2005
Old Oct 16, 2005 | 07:48 PM
5lugSlug's Avatar
Its in a 1998 Honda Civic EX if that helps
Old Oct 17, 2005 | 10:20 AM
5lugSlug's Avatar
any ideas???
Old Oct 17, 2005 | 10:54 AM
2-7offsuit's Avatar
I'm confused, I'm not sure what the "Eurolite Dash kit thing" is. Did you take off the gauge faces? or did you swap the whole cluster?
Old Oct 17, 2005 | 11:12 AM
5lugSlug's Avatar
Default Re: (2-7offsuit)
it was a blue gay *** face modification, but when i took them off, my stock cluster isnt working
Old Oct 17, 2005 | 01:03 PM
TheIntegraGuy's Avatar
Default Re: (EK-tacy98)
How was it installed and how was it removed? Sounds like some wires may be crossed or touching something else. An APEXi RSM will solve the trick! J/K.
However, I would check all the connections to insure proper wiring connections.
Old Oct 17, 2005 | 04:30 PM
5lugSlug's Avatar
just dropped it off at the shop... let u know what was wrong tomarrow
Old Oct 17, 2005 | 07:22 PM
99dcivic's Avatar
having the same problem....
Old Oct 17, 2005 | 08:00 PM
AbitAvenger's Avatar
sounds like some wires are shorting out on something...
Old Oct 17, 2005 | 08:04 PM
5lugSlug's Avatar
Default Re: (AbitAvenger)
i had a bad feeling its going to be the circuit board
lets pray its not
Old Oct 18, 2005 | 10:06 AM
99dcivic's Avatar
God, im trying to figure out whats wrong with mine. I doubt its the dimmer switch but who knows...
edit: seem like my instrument light is not reading the fuse...
Modified by 99dcivic at 11:24 AM 10/18/2005
Old Oct 18, 2005 | 11:39 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-tacy98 &raquo;</TD></TR><TR><TD CLASS="quote">i had a bad feeling its going to be the circuit board
lets pray its not</TD></TR></TABLE>
What exactly is the circuit board? The ECU? Other than the ECU, it's just wires and connectors.
Old Oct 18, 2005 | 03:22 PM
5lugSlug's Avatar
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
What exactly is the circuit board? The ECU? Other than the ECU, it's just wires and connectors.</TD></TR></TABLE>
take out ur gauges and ull see it behind them
but the problem was:
1) Dimmer switch was dead
2) Missing OEM Circiut board (i only had the gay Eurolite one)
3) Fried some lights
Total: $260
- $120 for new gauges (old milage was 73,000 - now it says 43,520 )
- $140 for labor (4 hours of new wiring and such)
oh well, its fixed now
j3wman
Jan 9, 2012 10:34 AM
JJGL-EF90
Feb 21, 2011 11:37 AM
linnhatch
Aug 21, 2009 07:36 PM
5-gen
Jun 15, 2007 05:54 AM
